Old 05-12-2011, 10:23 AM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Default Model 1 Tiller.... will be working on it
I hope to get outside today to look at my Model 1 Tiller. The tines won't turn, but everything else is turning. Something inside the chain drive housing must have failed. I went to Cub's site and printed out a parts diagram and list.
Does anyone have any experience in this area? Any pointers and/or gotcha's?
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 05-12-2011, 12:47 PM
Sugarmaker's Avatar
I will be watching as the #1 tiller I have needs a lot of TLC.
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 05-12-2011, 01:37 PM
ajgross ajgross is offline
Inactive Member
I don't really have any experience working n these yet, but I will soon. I have a #1 tiller and a 1A tiller. The 1A is in pieces and getting ready to be reassembled. The biggest problem I see with them, is the fact that the main gasket is NLA. Both of us will have to cut a new one. My biggest question is do you put any kind of lube inside the chain drive or do you basically just lube the chains real good.
AJ
Old 05-13-2011, 07:39 AM
engel177 engel177 is offline
I friend of mine had the exact same thing happen. A key sheared inside on the lower sprocket. We tried to disassemble the thing ourselves, but ended up taking it to a machine shop to have the big drive pulley pressed off. A word of advice- when you put it back together, use plenty of Never-Seez on the pulley shaft! Also, I almost positive my friend added filler and drain plugs on the chain housing, so the lube can be changed without taking the thing apart.
Old 05-13-2011, 09:42 AM
nra1ifer's Avatar
Thanks for the advice. Didn't get to it yesterday, hopefully today.
nra1ifer
Old 05-14-2011, 07:17 AM
nra1ifer's Avatar
Got it taken apart yesterday. Not a fun job. But, it's amazing how heavily-built this tiller is. I found that a couple of shear pins on one of the sprockets had sheared, probably when I hit a rock. It will be awhile before I get this thing put back together. I'll take the time to clean it all up and replace several bearings while I have it apart. Luckily, I have an old Troy-Bilt Horse to use. That's what I used exclusively before I found this 123 with the tiller attached.
nra1ifer
Old 07-30-2011, 09:42 PM
nra1ifer's Avatar
Well, it's still in pieces. It's been too danged hot to mess with the tiller, and I still need to get a couple of bearings off of their shafts. Seems that they grew together. Not having much luck getting them off. Once that's done, I'll order the bearings and get started putting the tiller back together. I'd love to see this back together, but it'll be later this fall/winter, I'm sure.
I really miss getting to use it!
nra1ifer
Old 07-31-2011, 07:45 AM
scleve scleve is offline
If possible take pictures as you reassemble it!
Old 05-11-2017, 07:37 AM
x.bhamcb x.bhamcb is offline
Sorry to resurrect an old thread, but I have a #2 tiller with the same symptoms. I was tilling and hit a rock and now all the shafts spin except the one with the tines on it. Are the pins that sheared at the interface between the sprocket and the shaft? I don't see anything indicated there in the parts manual.
Old 05-11-2017, 10:35 AM
He had to be talking about the pin that holds the tine shaft to the drive shaft. That is the only place there is a bolt. All the sprockets are made on the shaft. Either you sheared one of those bolts, or broke a chain.
