My 129 starts-runs for about 5 seconds-then stalls. As it stalls fuel blows out the carb throat. Anyone know where I should start? Sounds like ignition. Point gap? Coil test specs? Condensor test specs. Looks like an auto regulator in the bat. box. Should that be grounded?
"Hooper drives the boat Chief." ![]() 129, 1650, 782, 1541, 2185, 2145, Ariens S14, AIRENS GT20, JD 318 W/44 BUCKET, JD 317, |
Helloooooooooooooo,
Anyway, The engine is cranking but I'm getting no spark and no power to points lead. I was going to try a new voltage regulator. Anyone have an idea?
Might be the coil as well. Check for clean grounds as well. Wiring gremlins? Here's a link to the wiring diagram.
http://www.onlycubcadets.net/forum/showthread.php?t=22 |
By your first message i would say carb, if it started and the quit. check the values on you coil the are in the library on this sight. i always get spark first and go from there. have you done any work to you carb lately?
Have you driven a cub lately
Havent started on the carb yet. Supposedly it was rebuilt according to the seller but who knows. It did fire and ran for about 5 seconds and shut down. When I got it to the shop it wouldn't fire or spark at all. Checked coil values-good. The volt regulator on the outside there is a coil wrapped very thin wire around a solid conductor that appears to be burnt. I think it shorted because the rubber isolators are broken off. Can I use a solid state auto style regulator?
The crimped head on the negative coil wire was faulty causing an intermttent circuit to the points. ran a new wire and it runs wicked good now. I'm off to pick up a 782 I found on Cape Cod. It has the MK2 engine.
I have a tendency to crimp a connection, solder it together, then heat shrink it. That was a trick I figured out doing car stereos a long time ago. My stuff always worked better than my friends.
104 to 127 conversion with dual 6x12s, hydraulics snow/dirt plow 1200 Quietline 44" mower QA-36 snow thrower |
