Old 05-28-2011, 11:23 PM
Did a bunch of yard cleanup today. Finally sawed up some out of control brush.
Looking good. That new Gator trailer might work better, size wise. I love using my 5X8 behind the 784.
Old 05-28-2011, 11:37 PM
Nice pic, Adrian! You had that trailer loaded!
Old 05-28-2011, 11:40 PM
That's right!
Old 05-29-2011, 07:57 PM
CaptMax's Avatar
CaptMax CaptMax is offline
Pulled the rear cover seal on the 102 today. I was going to change the Hy-Tran fluid and expected to see the white snot from the moisture over the years. Was shocked when I found the inside looking like new and fluids draining from the axle shafts like it's supposed to. Needless to say the fluid is being changed now and I will be all set for another 46 years. Nice to see good old American quality holds up to whatever is thrown at it. Now to go look up those torque specs for the cover and button everything back up.
CaptMax
Old 05-29-2011, 10:50 PM
MrGitrdone41's Avatar
I cut some grass with the 128 than the belt broke! That made me mad because i have no tractor to finsh the front yard the 1812 has a broke todle cable. I was thinking about seeing if i could use the naighbor's JD but it is a JD lol! I'll have to Get a starter for for my JD. Oh what fun
1988 1812,dual ports
1973 108
1968 125
Old 05-30-2011, 08:41 AM
Sugarmaker's Avatar
Saturday between rain drops I mowed with the 127. Sheared the roll pin in the drive shaft at the engine end. Had to have the wife tow me back to the house with the 122. Replaced the roll pin with a 1/4 inch bolt and that lasted till I had most of the lawn completed.
Sunday the 102 was the tractor of choice to pull the small wagon with six honey supers down to the apiary. Also used the 102 to pull the argi-fab wagon to clean up some branches from the orchard.
Hope everyone has a great Memorial Day!
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 05-30-2011, 12:54 PM
ajgross ajgross is offline
Inactive Member
I got the gearbox for my tiller painted yesterday and installed today. I think it turned out pretty good. I'll have to get pics of it mounted on the 682.
AJ
Old 05-30-2011, 03:45 PM
aagitch's Avatar
aagitch aagitch is offline
I caught the Pandorians eyeballing my super today. I guess I'll have to start locking it up in the shed!
Adrian
2072 (789513)
Old 05-30-2011, 06:21 PM
I FINALLY was able to disk the garden today. The heat worked nicely to dry out the dirt enough. I have a hydro lift and am still wore out, LOL. But I sure had fun. I have another garden to do tomorrow. I will probably sharpen the blades on the deck while it is off and get it greased up real good and cleaned out from underneath. All the wet mowing is not good for the deck. We also just planted some tomato plants, onions, beets, leaf lettuce, and peppers. Been a good day.
Old 05-30-2011, 09:35 PM
I now have matching duals on the 100! Here's some pics!
