Old 06-02-2011, 01:25 PM
marshallj25 marshallj25 is offline
Default Cub Cadet 122 disassembly
I've posted before about the Cub Cadet 122 that I inherited. I'm in the process of restoring it, and I have it all taken apart now. Here are some pictures:
One of the bolt heads sheared off when I tried to unbolt the engine. I'll have to work on that later. I also need to decide whether to paint the engine yellow or leave it black.
When I went to unbolt the transaxle from the frame, water began pouring out of the hole.
Once it drained from that hole and I took the drain plug out, a ton of water came out of there, too, and made my drain pan overflow.
Next up will be sanding the paint a bit and then applying some automotive paint to it. I'm thinking of going with a primer coat, a base coat, and then a clear coat in the original colors. I also need to find a grille for the front and the piece that holds the headlights in place. My decals arrived from Maple Hunter Decals the other day, so I'm getting closer.
Old 06-02-2011, 01:32 PM
Thanks for the update pics! You've been busy!
Old 06-02-2011, 01:59 PM
Everything looks great. That's a lot of water in that rear axle. Be sure to take lots of pics!
Place a want ad in the wanted section of the site and if that doesn't work call or email one of our site sponsers.
Old 06-02-2011, 02:15 PM
cub149's Avatar
cub149 cub149 is offline
How can that much water get in the rear end? Through the shifter? I'm anxious to see the gears and what condition they are in.
Looks like you are diving right in, post pics of your progress.
Chip T.
Drexel NC
Old 06-02-2011, 03:39 PM
kesslerbmw kesslerbmw is offline
Awesome pics, Look forward to more, I can't wait to start on my 102 soon!
Old 06-02-2011, 04:56 PM
hydrocub hydrocub is offline
Wow ...you sure that's not a Hydro ?
Old 06-03-2011, 10:20 AM
Yeah, the shifter wasn't in place and I could see down into the transmission from the top of the tractor. It sat like that outside for years.
I don't want to take the transmission apart if I don't have to. I want to see the condition that the gears are in but I don't want to create more problems for myself.
Old 06-03-2011, 11:01 AM
jmroy's Avatar
jmroy jmroy is offline
Just try driving it when you get it back together, if there's a lot of noise and resistance then it'll need a tear down.
Web Developer - Need a website? Contact me.
