Old 05-26-2011, 10:17 AM
cubby123's Avatar
cubby123 cubby123 is offline
Cubs are pretty scarce around here, unless you are at my house or my brothers house, then they are pretty plentiful.
When looking for Cubs in these parts you pretty-much have to take what you can get and then "make" what you want out of them.
Almost none of the ones that I have found have headlights, so I usually have to fabricate my own. I was wanting some lights on my recently acquired 125. Along with some advice from grampascub (Thank you), I started out with a "blank" panel from a 107 that I parted out some time ago. I did some measuring, cut some holes, did a little bead blasting and painting and here's what I came up with.
Hmm I acquired a 125 saturday and was thinking bout doing the same thing, cuz its got the solid headlight panel. I am thinking bout cutting some holes at my machine shop class at school. How did you mount the lights on the other side?
if you want a real tractor, you need a CUB CADET!!
Old 05-26-2011, 10:30 AM
TEET's Avatar
TEET TEET is offline
Check out Kelly's cool custom light set up too...pretty sweet!
http://www.onlycubcadets.net/forum/s...ad.php?t=10289
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 06-06-2011, 11:16 AM
cubby123's Avatar
Jeff (teet)
Heres what I ended up doing to mine, I cut two 4.030 holes to measurement and drilled two holes .500 out from the holes cut for the brackets and BOOM, there she is. Not too bad for an amateur machinist
