Old 06-06-2011, 11:25 AM
cubby123's Avatar
cubby123 cubby123 is offline
Default 125 deck
Well the PO gave me a deck for my 125 and one for my 123. The 125 one is in overall decent condition. Gotta grease the bearings and replace the blades belt hooked it up to the tractor to try it and it works other than the loose belt. Pulling it off and painting/repairing whats needed and then putting it to work. The only thing it needed as of right now was the mule drive tension spring. I threw a spring on it and it worked, so wish me luck on the rest
if you want a real tractor, you need a CUB CADET!!
