Old 06-30-2011, 10:23 AM
CaptMax's Avatar
CaptMax CaptMax is offline
Default 36" or 42" snow thrower?
I am looking to purchase a snow thrower for my 102 Cub. As I only have a 10 HP motor should I look for a 36" or 42" model? I do have the creeper gear option but don't want to over work the motor having it struggle with a thrower that is too big. I did pick up a 1A U111 tiller with the extensions so I can always shorten that down to the smaller size if need be. What are everyone's thoughts about the size thrower I should look for, and what size tiller I should run? As I don't have the QA option installed on my tractor what would be the correct model for the thrower I should try and find? Sorry for all the questions, I'm still learning.
CaptMax
PS. Northern Michigan here so we do get deep snow once in awhile too.
Old 06-30-2011, 01:31 PM
I would stick with a 36" snowthrower. I think a CW-36 or QA-36 is what you need. You might be able to get by with a 42" one, but you'd have to go slower. I can kill the 18 hp engine on my 782 with my QA-36A if I feed it too fast. The 36" ones will also be lighter, which will matter unless you have a spring assist or hydraulic lift.
Old 06-30-2011, 10:20 PM
I was told a tiller with both extensions requires at least a 14hp,but I never had a chance to test it out.
A 36" thrower will be fine.And yes the 42" is a bit heavier...
Up to 534 and counting...
Old 06-30-2011, 10:38 PM
CaptMax's Avatar
Thanks for your response guys. Now to go shopping before it snows.
CaptMax
