Old 07-09-2011, 01:33 PM
Guitar Guy Guitar Guy is offline
Default Which ags ?
I have spare rims to accomodate either the wide or narrow rear tires for my wide frame 1000. I have wheel weights of 60 lb each, and I weigh 200 lb.
I'm up in the air about getting the 10.50 or 8.50 ags. I mostly use the tractor for mowing, and I'm wanting to get away from spinning on damp grassy slopes.
I'm leaning toward the more narrow ones if they're less expensive. Would the wider ones make less of an imprint on the yard? Any suggestions, pros/ cons, opinions? Thx.
Josh P
Old 07-09-2011, 02:06 PM
CaptMax's Avatar
CaptMax CaptMax is offline
I love my Carlisle Tru-Powers. They are 23x10.5x12's. They don't seem to hurt the lawn one bit, but then I'm not spinning them either.
CaptMax
Old 07-09-2011, 03:10 PM
I run the wide ones on everything I get if I can. My 128 came factory with the 8.50's and as far as I know they did great too. I have the Deestone 10.50's on the 784 with loaded tires and it just does not spin in the yard at all. Just pulls nice and strong and have never left an unsightly mark yet.
Old 07-09-2011, 08:59 PM
Josh P
Josh on your 1000 I would use the 10.50 Carlisle Tru-Powers. They are very flat and have tons of grip. I would load the tires as well. You'll gain about 180lbs for both tires.
Old 07-10-2011, 08:53 PM
I vote for the Tru Powers, as well.
Old 07-10-2011, 09:20 PM
Thx guys. Yes those Carlisles look sweet, although I may have to go with the Deestones for $$ reasons.
I do think I'll go with the wider ones, the 10.50 size.
CaptMax, that's a great picture. Your machine looks awesome with those tires and stainless sleeve hitch adapter.
Josh
Old 07-10-2011, 09:44 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Nanco front and rears.Loaded and no air in tires...lol Holds my fat can up and they don't leak either. I didn't have the cash flow to buy the Carlisles.My tires are 4 plys as well..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 07-10-2011, 10:54 PM
Deestones 10.50's:
They dig and pull awesome. The Carlisles are nice but I have no issue with the Deestones at all.
Old 07-11-2011, 12:05 AM
westofb's Avatar
westofb westofb is offline
I went with a set of the Deestone 23-8.50-12's and tri ribs up front, saved the larger set of wheels for new turfs for the 149. I can't tell you how the work but they are 6 ply rated and it rolls around the shop nicely!
Jeff
Brookfield, MO
________________
Old 07-11-2011, 12:56 AM
Josh
Josh I have a set of deestones and love them but they are a narrower tire next to tru powers. The 10.50 are slightly larger then 8.50. The deestones proform very well and I would buy another set. I can under stand the buget reason.
