Old 07-08-2011, 07:47 PM
AMCJavelin74 AMCJavelin74 is offline
if it looks kinda rough, count out $300 in 20s on the hood and see if he'll take that. Counting them out 20, 40, 60, 80... and him seeing that stack of bills gets folks excited. It's a good wheelin' and dealin' tactic.
Non-running: 100 max, unless it's been maintained and/or looks good.
Running rough condition $300 max
Running clean condition $500 max tractor only.
That's what I'd pay, but really it's worth as much someone is willing to pay for it.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 07-09-2011, 07:18 AM
And in the transition between IH and CCC, some CI rears are black on CCC-built machines assembled from mostly IH parts, before serial number 720,000.
Old 07-13-2011, 10:51 AM
jfm-ga jfm-ga is offline
I was thinking $500 tops myself, but he's at $700 and doesn't appear amenable to coming down any. Time will tell. If he does, however, I'll need to check it out a little more. For example, how does the hydro tranny work? There are two sliders on the right side of the dash. The one on the far right is the speed control, but what is the one next to it?
And, if I take it out on the lot and operate it, how do I give the transmission a good test to be sure it is okay?
Also, is there a pdf manual available for this unit, or, perhaps, the 682?
Old 07-13-2011, 01:59 PM
ljones's Avatar
ljones ljones is offline
Here is the pdf owners manual. http://ccmanuals.info/pdf/682-782%20...s%20Manual.pdf
Old 07-13-2011, 04:31 PM
Originally Posted by ljones View Post
Thanks for the manual. Hope I'll soon have a real use for it. :-)
Old 07-18-2011, 12:13 PM
Any thoughts on how to test the hydro transmission when I drive it so that I know its working correctly - what to look, listen for, etc.? Never operated one of these before.
Old 07-18-2011, 01:11 PM
young enthusiest's Avatar
If it whines and growled it needs new fluid and filter. If it is very jerky and not smooth to accelerate, the trunnion needs work. These transmissions are virtually indestructable by normal use. If it spins the tires on grass it's probably alright!
