Old 07-24-2011, 08:52 AM
Nice find on the 147 Todd!
Old 07-24-2011, 09:45 PM
Default more pictures
Well did a little looking over the 147 today. The PO sure knows how to make a mess of things. Wonder why it didn't charge? Voltage reg. was new at one time, but where the two rubbers are on the top and bottom, they were broke and put together with black tape.
Next was the wiring, what a mess, there's breaks in the coating all threw it, and black tape!
Check out the battery holders position.
The grill shroud had two bolts holding it in place. I found an empty bottle of 5w-30 oil under the seat, he said he did change the oil! And also included was a bunch of nuts and bolts.
I'm thinking the headlight panel isn't original, but I'm not sure.
But the deck sure is nice
Old 07-24-2011, 09:57 PM
william1041200's Avatar
Todd- My 107 headlight panel matched the photo posted earlier- yours is not original in any way. The tail lights are identical to mine, and I had thought mine were aftermarket. (just so you know, I have at least one good red lens. or entire assy. ) Good luck fixing all the wiring, as the owner shorted the battery, really thought he was doing good...
In order to fit a 14hp in that tractor, What was done to the frame by IH ? Is that a special frame( one piece) or is it cut with a bolt in addition to widen it on the sides?
Best of luck on your new tractor!
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 07-24-2011, 09:59 PM
All I can say is that is SHOCKING the way he has the battery mounted.Those are not the correct lights,look like 1x4 1x5 style.Nice deck I may add.
William,
IH cut the frame and added a piece so it would clear the 14hp flywheel.
Up to 534 and counting...
Old 07-24-2011, 10:05 PM
TheSaturnV's Avatar
Simple solution really. IH cut the frame on each side and the pieces were folded outboard to make way. Then, a gusset was layered up on the outside and welded. I'll post a pic later if nobody beats me to it.
Old 07-24-2011, 10:23 PM
I see clearly. One other question for y'all : is it common for 1x7s to have the hood hinge pivots welded? Mine were, and all paint was gone around that area... looking at Zippys 147 I see the same exact thing. Can't say it was welded but the paint is gone like mine is.
snow/dirt plow
QA-36 snow thrower
Old 07-24-2011, 10:40 PM
Not on my106.It still has the original hood washers...Those prolly were repaired like the 147 I posted.
Old 07-26-2011, 12:26 PM
Sugarmaker's Avatar
zippy1,
Nice 147! The deck looks real solid too.
You did god on that road trip!
At least yours was running! I am about 30% into mine and still a lot of work and time ahead.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 07-26-2011, 04:33 PM
zippy1,
Regards,
Chris
Chris, yah I thought I did good up until today when I really got into it. The wiring is a nightmare, and it looks like the trunion needs some work big time. But for now just trying to find a good place to get a wiring harness.
There fun, but sometimes you just have to wonder what goes through some peoples heads the way things are fixed. I know I'm not the sharpest knife in the drawer, but man what some do.
Old 07-26-2011, 06:08 PM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
Nice 147 Todd!
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
