Old 07-23-2011, 01:58 AM
william1041200's Avatar
Mine does not have the cradle mod either, so I feel your pain. Completely removing the front axle helps a ton! Between the two front bolts, and leaning over the front tires took way too long to put in 4 bolts.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 07-23-2011, 11:30 AM
CC1650Dave's Avatar
With the front of the tractor suspended, it only takes a minute to pull the front axle pin and get yourself 4" or more of room to work on those front engine bolts. Really the way to go.
Old 07-26-2011, 10:55 AM
sbigler sbigler is offline
So I finally got it done. I had to mill out the bolt holes for the cradle. The slotted holes were at an angle; they would've lined up better if they were straighter. With the creative use of the engine hoist I got the ISO mounts lined up and tightened one at a time. The rest was a bolt on affair. ***Fwiw, buying the new style cradle doesn't bolt right in. The cradle I bought did not use flat stock. It was angle iron. The front tensioner pulley for the mower deck belt actually hit the cradle cross-piece. I had to cut a notch out of it so it would clear.
So, the progress is:
  • installed new ISO mounts (bottom only. I reused the OEM top ones) with new style cradle
  • installed carb kit
  • new air filter
  • new hydro filter
  • new fuel filter
  • changed oil
  • cleaned the gas tank
  • new PTO belt
  • two new mower deck spindles
  • one new mower deck pulley
  • primed and painted the engine bay
  • adjusted the steering box
  • replaced random missing bolts on the engine
  • fixed leaky front tire
  • fixed some rattly sheet metal on the exhaust
  • installed new hydro fan
  • installed new aluminum coupler thingy on the back of the flywheel that the drive shaft bolts to (cuz soft aluminum is crap and I stripped out one of bolt holes)
Done for a while. This tractor truly tested my patience and now I am sure I have more money and time into than I'll ever get out of it. But it did fire right up and I mowed the lawn today.
And those of you who removed the front axles, smart move. I'm sure that helped a lot.
