Old 08-16-2011, 09:18 PM
MrGitrdone41's Avatar
Originally Posted by green 4 acres View Post
do you have a good flow of gas to the carb ? and good new gas ? will it start and run for a few seconds ? would it run if the choke was set half way . throttle open wide? at carb. that might explain needs choke to run and runs rich . you adjust the valve clearance after the cam has opened & shut the valve
128 owner myself
Good gas flow,New gas, and yes it will run for a few seconds,it will not run on the choke half way.
1988 1812,dual ports
1973 108
1968 125
