Old 08-18-2011, 08:21 AM
scottneidert scottneidert is offline
Default 1811 Blade lift arm and rod
Ended up finding a blade for free from a neighbor, however It does not have the lift arm or rod. Going to order what I need on Cub Cadet Warehouse but I want to make sure I am getting the right thing. Will the following work? I have a 1811.
NEW LIFT ROD IH 548589 R1 28 inch 1-2 inch
SNOW DIRT BLADE WIDE FRAME 1968 AND UP SERIAL # 400,001 - 665,000
APPROX. 28inch LONG
USED SNOW DIRT BLADE LIFT ARM IH 473925 R1 759-3105
42 & 54 inch BLADE SERIAL # 400000 - BELOW
Thanks in advance for the help.
Old 08-18-2011, 08:33 AM
You could make your own lift rod.
http://www.onlycubcadets.net/forum/s...ead.php?t=4616
Old 08-18-2011, 11:39 AM
That's a sharp 100! I bolted my sub frame to the mule drive, just like the owner of the 100 did!
Old 08-19-2011, 10:24 AM
Any one know if these parts will work?
Old 08-19-2011, 02:14 PM
I found these part numbers at cubcadet.com
Diagram
Mount:
Rod:
Old 08-19-2011, 02:41 PM
What's your serial number?
Old 08-19-2011, 04:27 PM
mrcubcadet's Avatar
Or you could use some cable, like I ended up doing for my QA42A snowthrower.....
Just 6' of 840 lb cable, with two clamps...works on NF and WF tractors......and I have less than $5 in it.
-105___ Tiller
Old 08-19-2011, 05:36 PM
Nice work, Conner!
Old 08-19-2011, 08:59 PM
mrcubcadet's Avatar
Thanks, Allen!
-105___ Tiller
Old 04-06-2022, 10:53 AM
evaninsky evaninsky is offline
Default cable vs rod
I thought about trying this... does it work with just the weight of the blade or does a stiff rod help hold the blade down ??
