Old 09-12-2011, 10:31 PM
hydrocub hydrocub is offline
Default Steering 2.0
While we are talking about streeing rebuilds .... Did mine ,but
I have about 20 degrees left / right of "slop" when turning the wheel ,
What I mean , I have a little slop in there where nothing moves ...
What adjustment should I make ?
Old 09-12-2011, 11:38 PM
bocephus1991's Avatar
Did you replace the stud cam follower? if not its probably worn down,they are kinds pricy but you can make your own. How about the tie rod ends? Could be and one of those or the drag link that connects to the lever assembly. I'm not an expert,hope this helps!
Brian
Old 09-13-2011, 09:51 AM
Yes ...let me clarify . Replaced follower , and did the nice bearing up grade .
I feel like the plug is adjusted correctly . If I tighten the follower and plug
more , I get to much resistance , but still have the slop .
Old 09-13-2011, 10:45 AM
Sugarmaker's Avatar
When I tuned mine I felt some "slop" at each end of the clock, but when in the center I didn't have much. So that's where I left the adjustment of the cam follower. I have not mounted this in the tractor yet so time will tell!
My Cub guy in Ohio says that if you have less than half a turn, of the steering wheel, your in good shape
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 09-13-2011, 11:50 AM
Thanks Sugarmaker ....it's less than half for sure, but it drives me crazy .
No pun intended .
Old 09-13-2011, 11:55 AM
westofb's Avatar
westofb westofb is offline
It sounds like you and put the same parts in out collumn rebuilds, yours is having slop, mine has none, so I assume yours is not adjusted just right. It's been awhile since I redid mine, but I am thinking I did my adjusts as such:
after getting the main shaft and all the bearings and what not back in the column, I put on the end cap first and tightened it down enough at that time to take the end play out of the main shaft. Next I installed the side cover/ cam follower cover, and associated parts, at this point I left the follower loose, I was more concerned about getting the side plate adjusted, again tightening the new jamb nut down as I worked the plate back and forth, if you left it too loose, it tends to want to not only have end play, but will rock a slight amount side to side, I adjusted this part so that there was good compression of the foam gasket (actually the metal sleeve it sat in just barely misses making contact) and there was no side to side movement, and of course no end play. At this point every part is back on the column, just haven't messed with the follower yet, at that point I clamped the column down (a vice would be great), added a steering wheel and began final adjustments of the follower and end plug. Putting the steering wheel on helps alot, it will magnify any adjustments you have out of wack, I started with the follower basically in the center of the gear box, I tightened it down until I felt just a slight resistance, then begin to rotate the steering wheel slowly lock to lock, while doing this, tighten the follower down, you want it making contact with the sides of the worn gear, so tighten it until you can feel it begins to put resistance on the steering itself, they back it off slightly (by slowly turning the steering, you will feel it hit it's sweet spot, is hard to explain, but as you adjust each piece, you need for those adjustments to add to the resistance of the steering itself, ever so slightly, no resistance=slop). After getting the follower set, the last piece (and the first) to be set is the end plug. With everything else adjusted, slowly turn the column lock to lock, if the mainshaft doesn't try to move up or down as you reach the lock postion of the wheel, you are there, if it tries to move, just slightly up or down, tighten the end plug another notch. That should have your steering adjusted with no slop, I used all new ball joints as well, it turns very easy, and the slightest movement of the wheel is transferred to the front wheels. I don't think I forgot any steps, and I did use the manual as a guide for adjusting mine, but I may have improvised on a set or two, but I couldn't be happier about the end result.
Jeff
Brookfield, MO
________________
Old 09-13-2011, 01:33 PM
I'm pretty much right on with you Jeff, except for the side cover . I'm not
sure that I have it tight as it should be . Believe I will start there . Everything
in it is new except balls and races ( they were in good condition ) and
new tyrod ends ....
