Old 09-25-2011, 06:23 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Default GPM and PSI output
I am wondering what kind of GPM and PSI the 782 ported hydro can produce? I believe that I was told that they are set at 550psi, but that they can be turned up to 1000psi. I have been trying to find the answer, but cannot. I am thinking one of these are in my future on the 882
http://www.northerntool.com/shop/too...5410_200395410
http://www.northerntool.com/shop/too...5528_200365528
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-25-2011, 06:36 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Link isn't working for me ,what are you looking at.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 09-25-2011, 06:49 PM
You need a dedicated pump to run that.
Old 09-26-2011, 04:29 PM
MrGitrdone41's Avatar
The psi on the 82 series is 800-900 psi. The 123-1650 400-550
1988 1812,dual ports
1973 108
1968 125
Old 09-26-2011, 07:44 PM
CubDieselFan's Avatar
You would need a separate pump, like Matt said. Also you would put more wear on your tractor than is necessary. It just does not take that much horsepower to split wood.
Old 09-26-2011, 08:27 PM
LarryW's Avatar
LarryW LarryW is offline
Just curious what is the gpm on the 82? And what about my 1872 psi/gpm?
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-26-2011, 09:04 PM
Although the pressure is adjustable, the output of the charge pump is low. Just look @ how slowly the deck raises/lowers and figure how much slower a larger cyl will operate.
yea it will work and split wood but I think you could have lunch before it would. cycle
Old 09-26-2011, 09:12 PM
There's 3 different charge pump displacements (.19, .3, or .33 in3/rev) given in the Sundstrand service manual, but I think it's the smallest one, so the flowrate would be about 3GPM at 3600 RPM, I think. That would be true for any of the ported hydros used in a CC GT...they are all essentially the same.
Regardless, you need a dedicated 5+GPM pump to run anything but a small auxiliary cylinder. The charge pump is only for intermittent use actuating cylinders and stuff. You'd probably ruin a hydro pump by running a loader or logsplitter off of it.
Old 09-27-2011, 07:07 PM
Yamaguy's Avatar
Kind of what I figured. I like the thought of not having a different engine for everything I want to do (generator, log splitter, ect) Especially for as often as I need them which is the same reasoning behind having attachments for the tractors in the first place. I may buy one and then just run a pump off the pto. I would really like to find a log splitter with a blown engine, or at least find the I beam and what not.
Dale
