Old 10-01-2011, 09:08 AM
krhoover krhoover is offline
Default after market coil, condensor
Can someone give me some part #s for a coil and condensor that I may be able to get at advance auto or another parts store for 14hp 1450/ thanks
Old 10-01-2011, 09:44 AM
Condenser IH # 62188C1, Kohler # 230722-S, NAPA # 7-01338
Engine Coil Kohler NAPA # 4151921S
Old 10-01-2011, 03:17 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
WOW i just went to napa site to see there price for that coil and it lists for 70.37 EACH
at that price you may be better off with stock or one of our sponcers.
http://http://tewarehouse.com/7-01634?sc=2&category=84
i have one from tulsa to have on the shelf for 22.23 + shipping
i am all about supporting the local economy but at 1/3 the price i know when to go elsewhere
Old 10-01-2011, 03:21 PM
Those are the only after market numbers I have. I figured he could have them cross referenced?
Old 10-01-2011, 03:45 PM
bsyphrit's Avatar
did not think of crossing it, i do not know about others here but i like to keep a stock on hand of things that will break or wear out because with out fail they go out when it is the most inconvenient, weekends or after store hours.
last week i was cutting grass with my woods deck and 1 hour of day light left and the belt said it had enough but i had one on hand i bought 4 years ago, not a bad price of 45 dollars for a 113 inch 5/8 wide belt. and i had to look up the routing of the belt but i got the yard done before dark.
for the cub got back up coil condenser points and a gasket set along with other stuff that will get me by in a pinch, like i said it is not if it will fail just whenis the mystery
Old 10-02-2011, 08:14 AM
mickb72 mickb72 is offline
Default coil
For a coil try napa ic14sb it's oil filled not expoxy, has the right resistance,about 20$. What's the difference between a 6v to 12v condencer. Can they be used? Mike
Old 10-02-2011, 09:29 AM
Thanks for the replies. I have some old automotive coils off of differnt motors I have around, is there a way to check coils and condensors? I really need to get this 1450 going and am looking to pinpoint the problem instead of just changing parts. The day I got this 1450 it quit, I called the PO and took it back to him, he replaced the coil and it fixed it, I'm wondering if something is causing the coil to fail?
Old 10-02-2011, 10:23 AM
Coil Link:
http://www.onlycubcadets.net/forum/showthread.php?t=11
Old 10-04-2011, 05:39 PM
Put a coil that I had off of an old truck engine, now I have a weak spark across the points. This will be the second coil that has failed on this 1450, any ideas as to what may be causing the failures. i don't want to replace the coil and have it fail if there is a problem elsewhere.
Old 10-04-2011, 06:00 PM
When the points open to disconnect the ground connection you get instant spark. The condenser serves to enhance the spark by greatly increasing the voltage to the input of the coil. Weak spark is often the result of a bad condenser....
