We have noticed that whenever our 782D is sitting on concrete the whole tractor leans to where the left side is a little lower than the right. It doesn't affect it mowing except when you are mowing on the side of a hill. The tires are the same size too.
Anyone have any ideas why it does this?
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Are the tires on each side inflated the same?
You could also have a bent frame (unlikely) or broken/missing frame-to-trans bolts, or a broken transaxle case (more likely). |
Bent frame, didnt notice mine till I took the fender pan off.
My 1572 lean was the result of a crack in the frame starting by the rear engine bolt hole and going up to where the frame spreads and the typical broken rearend mounting ear and someone's attempt to drill another hole further back. I say attempt because not only was the hole not in line with the original but was drilled crooked. NICE!
