Old 10-10-2011, 08:50 PM
only1stegall's Avatar
only1stegall only1stegall is offline
Default few questions about my factory lift on a 149.. down pressure? ...3pt lift pros cons
Is my factory hydrulic lift capable of supplying down pressure to an attachment? what would be involved in making it capable of applying down pressure?
I was also looking at the 3 point lift kit offered by xtrememotor works I think it was.. i know a few of the guys here use them... I was wondering what the advantages of having the cat 0 over the sleeve hitch are...
mowing LT1045, plowing 149, tilling 149, parts 149...
plows, harrows, cultivators, box blade, tillers...
I like fast cars, big trucks, and yellow tractors!
My photo album
Old 10-10-2011, 08:56 PM
heres an example of the kit offered by xtrememotorworks.com
looks to be pretty nice quality.. Its a little steep at $450 dollars but I like the looks and idea of the 3pt vs the sleeve hitch..
My photo album
Old 10-10-2011, 09:04 PM
There should be a section in the service manual that shows how to set down pressure.
As for the Cat 0, it gives you some options of larger equipment than you would normally get for a Sleeve hitch. Down side is the $$$$ of Cat 0 equipment. You can buy a lot more Sleeve hitch attachments for less money and still essentially be able to do the same things as you would with a Cat O. Personally I like the sleeve hitch set up for the GT's and I am actually looking at an attachment A frame for my Cat 0 lift on my 982 so I can use the sleeve hitch attachments I already own.
Old 10-10-2011, 09:10 PM
only1stegall
Yes you can apply down pressure. You need a float lockout pin i believe they call it. Remove the tunnel cover and looks at the linkage for the lift. It may already be there. The pin is removed and stored backwards when not in use. I think our technical library may have the info on how it works.
The 3 point looks great, keep us posted if you get one. I know there are a few guys here that have them, hopefully they will hop in here and let you know how they work
Old 10-10-2011, 09:24 PM
only1stegall
done some searching and i didn't come up with any thing...
My photo album
Old 10-10-2011, 09:26 PM
Here you go:
http://www.ccmanuals.info/pdf/Float%...%20Install.pdf
Old 10-10-2011, 09:33 PM
check out what I just found on the parts tractor...
My photo album
Old 10-10-2011, 09:36 PM
Merk Merk is offline
Float lockout pin in place:
No float lock out pin:
Float lock out pin:
The only time I use float lock out pin is when plowing with my moldboard plow. My hitch for the moldboard plow was modified to put some down pressure and still have some float built into the system. You will break the pin in the lift arm if you try to put down pressure using a front blade. It can be a pain to change the pin.
Old 10-10-2011, 09:39 PM
Vince_o Vince_o is offline
Not to mention that the cat o stuff cost more Heres what Im going to do on the 1872. Fits perfect.
