Old 10-29-2011, 04:30 PM
gpapa gpapa is offline
Default Pulley Problem
Does anyone have a procedure for straightening a bent pulley? I have a NF hydraulic lift pulley that has a wobble in it. Thanks, Greg
Old 10-29-2011, 05:52 PM
YUP.....replacement.
Old 10-29-2011, 06:13 PM
I can't give up that easy!
Old 10-29-2011, 06:28 PM
Stamped steel?? just bend it!! I saw a guy just grab a power steering pulley on a Chevy S10 and bend it correct.
It might help to invite your big guy friend over.
Old 10-29-2011, 07:19 PM
You can spend a ton of hours trying to true up a bent pulley and you will probably never get it right. BTDT.
Being a HVAC/R Tech, I have found it is just easier and less costly to just replace the pulley.
Old 10-29-2011, 07:21 PM
LarryW's Avatar
LarryW LarryW is offline
I would check the hub area real close to make sure its not cracked. If you do bend it back double check it again. Im not sure how easy they bend or not but be careful of the pump shaft too if you are prying. Not sure how sturdy they are but it would suck to break that off, lol. Ive never looked at that area of a NF pump close enough to say how strong it is so maybe it is beefy. Im just saying.
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
