Old 08-24-2011, 03:41 PM
That looks so sweet! What happened to the stock pulley? Is the replacement the same size?
Old 08-24-2011, 04:25 PM
rhampshire rhampshire is offline
Stock pulley was trashed - it had an OD of 6.5". This one is 7" but the belt rides deep in the groove so it's close enough. Problem is I had to use a 34" belt instead of the stock 33", and I'm about out of adjustment. If the belt stretches any more I'll have to figure out a plan B. Oh I got pretty good at pulling the motor with a come along and two tie down straps since I had to do it three times...
Old 08-24-2011, 09:52 PM
I just found this thread.....wish I had earlier. I have a rockshaft set up for an electric lift in my 123 with a hydraulic lift on it. I did not have to cut mine at all, I just used 1 1/2" spacers instead of the 3/4" ones, which tightened up my pulley belt (which I believe may have been the incorrect belt) and works just fine. I do not like to cut into original parts, unless it is absolutely necessary, so I was able to work something out to solve the problem.
Well, its a moot point because you have yours installed and operational now. Your tractor looks very nice and your installation looks well done!!
Old 08-26-2011, 11:49 AM
My rockshaft was a little different than yours - I have read elsewhere that there were at least five different versions of these things, with the dimension shown in my first post being the difference between them.
For mine, I would have needed 2-1/4" spacers to make it work, and that would have been a real ankle smasher, so I chose to make it "correct" by modifying the tab on the rockshaft to be the correct width. I don't like cutting into parts like frames, fenders, hoods, etc., but I have no problem modifying a rockshaft. I may actually change to 1" spacers instead of the 3/4" ones to gain a little bit of belt tension adjustment with the 34" belt.
Old 09-06-2011, 06:00 PM
Well I finally had a chance to really put the new lift to the test... After about 1.5 hours of mowing, the belt had stretched a LOT and even twisted around a bunch, plus the input shaft seal started leaking...
Back to the drawing board, but at least it looks nice.
Old 09-06-2011, 06:41 PM
Your biggest problem is that pulley...it's the wrong size for the belt. You need a pulley meant for a 3/8" belt. That one looks like it is for a 1/2" belt.
Old 09-07-2011, 08:35 AM
mmzullo mmzullo is offline
Do you still have the orginal pulley? If that was actually under 7 inches it was for an original tractor. I was told the the orignals used a smaller pulley then the later pumps. Rare pulley!!
By the way nice looking tractor!!!!
Old 09-07-2011, 11:04 AM
Yeah, I think the pulley definitely has a lot to do with the belt problem - I'm looking at getting a 6.5" browing pulley and a 1/2" split taper bushing.
The pulley it came with was pretty much exactly 6.5" on the OD. I tossed it - it was bent such that it would wobble when spun, but the biggest problem was that one edge was smashed in pretty bad such that it would squish the belt. I tried to fix it but just made it worse... How big is the pulley supposed to be for a NF? The 7" one on there now barely fits - any bigger and it would rub the PTO release rod.
Old 09-07-2011, 11:50 AM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Can a pulley that wobbles be fixed? I ask this is because the pulley on my Hydro lift has a wobble in it as well.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-07-2011, 01:38 PM
scleve scleve is offline
Yes, a machine shop can straighten it and tighten the bushing. Might be expensive unless you just want to keep it original.
