Old 09-21-2011, 04:08 PM
I just sold two Magnums this month...Must be a run on these things...Both of them were series II with remote oil filters....Good luck and just search CL.....
The series I/series II designation is for the KT-17 only and does not apply to the Magnum engines.
Old 09-21-2011, 09:00 PM
FarmFresh's Avatar
Is there much work to installing the Command 18 in the place of the KT. I found one out of a 1864 and I think I will pick it up this weekend. Im not worried about the wiring, but I need it done in a hurry so I dont want to have to order a bunch of adapters and other custom pieces to adapt it driveshaft and pto wise. Thanks for the replies
149 Raised Bed Tractor
1512 Being restored
1450 Missing its heart
Original 1961 Red No options
782D Missing Engine
Old 09-21-2011, 09:06 PM
Wiring and a custom-length driveshaft, and possibly some slight reconfiguring of the exhaust system will be your primary issues.
Old 09-24-2011, 12:06 AM
FarmFresh's Avatar
Picked up an 1810 tonight, it is in really decent shape I almost feel bad pulling the engine out of it to install it in the 782. It also came with a nice rebuilt 50" deck that will work nice on the red one. Thanks for the input, I am happy I went with the magnum 18, It should be alot less modifying.
1512 Being restored
782D Missing Engine
Old 09-24-2011, 09:06 AM
ajgross ajgross is offline
Inactive Member
Look in the IH section of this site for a link called "M-18 in my 782". It has all the wiring modifications explained.
AJ
Old 09-24-2011, 09:59 AM
Here is the thread link:
http://www.onlycubcadets.net/forum/s...ad.php?t=13167
Old 09-29-2011, 09:05 PM
FarmFresh's Avatar
I am having a rough time with kohler twins. When I bought the 1810 the engine was shaking pretty good when I looked at it. I assumed it was because it was missing two engine mount bolts and the other two were loose. So I pulled the magnum out last weekend and started cleaning it up tonight, and while fiddling with it I was turning it over by hand and heard some weird noises. The oil looked good and I did not hear anything bad while it was running other than rattling sheet metal. Well I pulled the plugs and turned it over and what do you know no air pushing out of one cylinder. Its got a broken rod and still runs on the good cylinder. I got really mad and thought about selling the whole lot of cubs. Now I have three out of commission tractors, the yard needs mowed, fall garden work is coming and snow is just around the corner, and to top it all off I used the rest of my cash to buy this nice looking P.O.S. 1810. I don't know what to do now. Thanks for listening to me vent.
1512 Being restored
782D Missing Engine
Old 09-29-2011, 10:32 PM
Man ,that blows like a rubber hose...
I would go back to the guy who sold you the 782 and beat him up with the rubber hose...LOL he should stand behind the equipment he sold you.Just my 2 cents.
Up to 530 and counting...
Old 09-30-2011, 07:56 AM
scleve scleve is offline
Don't give up. Something will come along better and cheaper if you keep a positive outlook.
O _____ O 27670 O 38245 O 49448 100 _____
All W/Fenders, 3 Point, Lights, Brinly Adapter
124 ______ 106 ______ 107 _______ 127 _______
All W/Hydro, 3 Point, Lights, Brinly Adapter
108 _______ W/Factory Electric Lift, 42" Blade, Brinly Adapter
109 _______ W/Factory Electric Lift, 1A Tiller Both/Ext
2 10" plows, Dbl Disk Harrow, Spring Tth Harrow, 2 42" Tool Bars, Box Blade, Yard Sweeper, Aerator 3 Sets Wh wts., Dethatcher, Garden Cart, York Rake(in pieces), Ect...
Old 09-30-2011, 05:28 PM
Take it apart and see what all is broken. For all you know, you might be able to make that into a good engine with a couple new rods and sets of rings.
