Old 09-20-2011, 09:49 PM
FarmFresh's Avatar
Default 782 Knocking after first time mowing.
Some may have seen my post about my new to me 782. Well after working on my 1450 loader project, I decided to take a break from that and mow for the first time with the 782. I had just got the 44" deck repaired and fitted to it that morning, and had never used the tractor for more than a few minutes at a time, so I was excited to work her a little bit. I mowed the yard for about 45 min. and when I was done I just tooled around to let it cool down on the way back to the shed, and when I idled it down I heard a "knock knock knock" so I quick shut it down checked the oil. It was fine, I let it cool down, checked timing(I knew it was done for but was trying to be optimistic) and fired it back up, still knocking. The previous owner said it was a series II kt17 and I believed him. He said he put new rods, pistons, and bored it. He told me he worked at a john deere dealer when these were new, so I believed he new what he was doing. That is why I had buying things that were just rebuilt. None of it matters because after it started knocking I checked the numbers on the cases and it is a series 1 P.O.S. anyway. I feel I was had. I don't know why it started knocking, maybe it has the wrong rods, bad machine work? I have no idea. So I am ticked and it ruined the rest of my sunday. Now I have to find a engine for it and install it before the plowday in October. And I had already disassembled the 1450 so I am without a mower.
Sorry this is long, but I had to vent about it.
I found out today I may have a line on a Honda GX620 from a guy at work, I don't know what it would take to install it and adapt the PTO but the price is right.
Any ideas or insights into my problem would be greatly appreciated. Thanks
149 Raised Bed Tractor
1512 Being restored
1450 Missing its heart
Original 1961 Red No options
782D Missing Engine
Old 09-20-2011, 10:10 PM
Vince_o Vince_o is offline
Man I hate to hear this!!!!!!!!! Ol Ugly Jim is in the same boat as you with the same thing, PO stuff.
From what I remember on the 982 the honda is a direct replacment. So Im guessing it would be the same for your 782.
Shouldnt a series 2 have an oil filter?
Old 09-20-2011, 10:15 PM
FarmFresh's Avatar
I guess the early Kt17 series II didn't have a filter provision, the differences were internal from what I understood. I guess you can't always trust previous owners, even if they are self proclaimed experts.
1512 Being restored
782D Missing Engine
Old 09-20-2011, 10:18 PM
You can't truly rebuild a series I, as most of the parts are NLA. If Series II/Magnum rods were used without having the oil hole drilled in the caps, it'll seize or throw a rod. I got a tractor real cheap because the idiot that 'rebuilt' the series I was too dumb to notice that difference.
Old 09-20-2011, 10:27 PM
FarmFresh's Avatar
Either way it is a boat anchor now. Luckily the price I bought it for was adjusted because I was assuming the engine was bad since he couldn't get it to run right. It went from a great deal to just retail for a blown up 782. I guess I can just try to salvage the tins and carb and anything else that can be reused or sold. Ohwell it will be better with a new engine anyway.
1512 Being restored
782D Missing Engine
Old 09-20-2011, 11:33 PM
scleve scleve is offline
Good luck with the retro.
Old 09-20-2011, 11:57 PM
cubs-n-bxrs's Avatar
I would shop around for a 2185 or equivalent cub that has the 18hp command engine in it. I just re powered my 682 with one and could not be happier. The thing runs like a bear. I had to retrofit the wiring harness from the 2185 which took a little longer but was well worth it. A lot of times you can pick them up off of Craigslist for a song. Just some thing to think about.
Old 09-21-2011, 06:02 AM
Kelly is right, look for a command and drop in there.
Old 09-21-2011, 09:21 AM
Question,
You compared the "numbers" on the cases---- or do you mean the sheet metal shrouding?
the kt1 and kt2's interchange sheet metal.
It is possible it is a series II in series 1's "clothing" you gotta look close as not all series II's have a filter provision.
if it is a II it is possibly worth fixing, if a series I like Matt says, not worth the effort.
just something to think about
Old 09-21-2011, 10:31 AM
Leadslingingdaddy's Avatar
I just sold two Magnums this month...Must be a run on these things....Good luck and just search CL....
I did the same thing for my JD318 as stated above and find a good Command engine and repower it.... I got the engine for 90 bucks!!!! since the PO couldnt figure out that the carb solenoid was the reason it was not getting fuel and I sold the deck and frame....
Deals are out there dont get discouraged...
