Old 10-07-2011, 06:43 PM
Start with the basics...are you getting 12V at the coil? How about at the points? If there's no electricity to those shiny new points, they aren't going to work. Also, take a piece of paper and run them through the new points to remove any oil that may be on them from the factory.
Old 10-07-2011, 07:07 PM
scleve scleve is offline
From South Carolina
O _____ O 27670 O 38245 O 49448 100 _____
All W/Fenders, 3 Point, Lights, Brinly Adapter
124 ______ 106 ______ 107 _______ 127 _______
All W/Hydro, 3 Point, Lights, Brinly Adapter
108 _______ W/Factory Electric Lift, 42" Blade, Brinly Adapter
109 _______ W/Factory Electric Lift, 1A Tiller Both/Ext
2 10" plows, Dbl Disk Harrow, Spring Tth Harrow, 2 42" Tool Bars, Box Blade, Yard Sweeper, Aerator 3 Sets Wh wts., Dethatcher, Garden Cart, York Rake(in pieces), Ect...
Old 10-07-2011, 08:03 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Keep in mind if the key is in the off position (or if the ignition switch is not functioning) jumping to the starter won't provide voltage to the ignition system even though the engine will crank.
Old 10-08-2011, 02:40 PM
Abeach6882 Abeach6882 is offline
i got it running after i found out i wasnt getting any power to the coil itself so i ran a wire directly to the coil from the battery and i fired right up. Guess i need to get me a new wiring harness or make me one. thanks for all your help.
Old 10-08-2011, 04:12 PM
If you keep that wire connected full time you will burn up your coil. That is why the coil power is made thru the ignition switch.
Old 10-08-2011, 09:44 PM
thanks for the heads up about the wire going to the coil. I have the wiring diagram but cant seem to get the ignition switch to work. there are so many wires that have been spliced that i dont know which wires lead to what so eventually i will be tearing the whole mower down and going through everything and attempting a restoration. I know there are several parts that i will neeed due to the prior owners neglect. If anybody knows where i can find a new hood, dash and dash tin for a relatively cheap price i would appreciate the info.
Old 10-08-2011, 09:51 PM
You need to put an add in our Wanted Section, and also give your Sponsors located at the top of every page a call or email with your needs. There is a company called Porch Electric that makes complete wiring harnesses for our Cubs. You might google them and check out their prices. I am going to get one of their harnesses for my 128 in a few months. They also sell their stuff on Evil Bay.
Old 10-10-2011, 12:31 PM
thanks Dewayne. i figured our the woring glitch over the weekebd after about an hour of tracing wires now it fires up with a key.
Tags
cub cadet 106, no spark, restoration
