Old 05-21-2012, 08:49 AM
Ok just got my 124 back together and now it's running 1000x better but now it's quit charging. Prior to taking it down it was charging fine
I took this as you tore down the K301 motor and now it is running 1000X better. During that process, you removed the S/G and simply re-installed it. Now the S/G won't charge.
Did I mis-read or misunderstand that..???
Old 05-21-2012, 09:39 AM
Originally Posted by aarolar View Post
Should have been a comma in there as in just before I tore the motor down to rebuild it I replaced the brushes and bushings in the S/G and up to the point I removed it from the motor during the rebuild it was working. Sometimes things get jumbled when transferring them from thoughts to text.
Ho key, unner-stood
Do check resistance to make sure there is not paint preventing a good ground and check the braided ground wire on the regulator, they are easily broken. or a terminal gets moved to touch something it shouldn't, as others mentioned
Luck!
Old 05-21-2012, 11:01 AM
aarolar aarolar is offline
You are exactly correct
