Old 03-13-2013, 04:09 PM
Nothing in the way on this one.
Old 03-15-2013, 12:25 AM
inspectorudy's Avatar
When I mounted my Craftsman johnny bucket to my 1811 the length of the moment arm made a BIG difference in how much power the lift had. I you attach that winch to that short of a handle you will burn out the winch most likely. I'm not saying it won't work but it won't have much strength to do much except to position something with no load on it. It might make more sense to use the winch as a lift vertically attached to the rear of the tractor and let gravity do the downward movement. That way if you double sheaved it it would have a lot lift of power but no down power. I made an electrically operated dump rear bed on my old golf cart using one of the HF $49 winches and it worked great. The bed was about 55% over center so that the cable of the winch held the bed level and when I useed the hhand remote to lower it then it would go to the full dump position. One click of the button and back up it came. The trick was having the dump bed be 55%past the CG instead of 50/50 which would have made the load the deciding factor as to whether it would dump or not. of the bed otherwise it would not have dumped :beerchug
1811 Hydro
Old 03-15-2013, 07:26 AM
Rudy
If you think about the 147 with the electric lift I doubt that the actuator had 2000 lbs. of force. Like I said this is a maybe project, not even sure I will do it at this point because I don’t have a need for a tractor with a lift. If I do I would probably set it up with a 2 or 3 part line just to slow the speed of the lift down and that would double or triple the pull from the winch.
Old 03-15-2013, 08:33 AM
Sam Mac,
Is that a 100 super build? I am very interested!
Sorry for the hijack!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 03-15-2013, 08:47 AM
vartz04 vartz04 is offline
Originally Posted by Randy Littrell View Post
Sam Mac,
Randy
No problem this thread got hijacked long before your post
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 03-15-2013, 09:23 AM
Vartz
I’m not trying to hijack this thread, sorry if that’s what you thought. I think your idea would work as you posted.
Randy
No it’s not a Super 100 this is the thread for the build.
http://www.onlycubcadets.net/forum/s...ad.php?t=20585
Just a play toy.
