Old 03-12-2013, 09:05 PM
vartz04 vartz04 is offline
Default Came up with a lift idea. What are your thoughts.
Well I was thinking about this today while in safety training for work (5th time ive taken the OSHA 10) What if you did the following
What if I made a small bracket that bolted onto the top 2 bolts on the rear dif cover and connected a actuator from there to the brinly adapter. You would have to use non floating lift straps but what should happen is the actuator moves up and that pushes the top link up by the lift straps. That in turn would move the link between the top link and the lift arm. You would just have to put the lift arm in float mode. That would also make it so it could lift and lower front implements.
It was just a day dream brain storm so maybe you guys could let me know if this would work or not. Here are a couple pictures showing what I mean.
Red line would be where the bracket would go, blue line would be the actuator.
Blue line on this is the actuator. I am assuming i could weld a flat bar connecting the lift tab to the two arms of the adapter to mount a bracket to on this side.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 03-12-2013, 10:27 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
so you kinda thinking something like this...
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 03-13-2013, 07:33 AM
I’m playing with the idea of using a small electric winch mounted at the rear of the tractor with the cable running forward to the lift handle. The winch would pull the handle back to lift the rear attachments. Only in the thinking stage at this point but Harbor Freight has a 2000 lb winch on sale for around $60.00
Old 03-13-2013, 07:44 AM
cubby102's Avatar
cubby102 cubby102 is offline
I used a electric actuator for the rear blade of my old 782 mainly so it.can operate independantly of Tue.front or.mid attachments
Old 03-13-2013, 09:35 AM
the winch would have to pull the bottom of the handle forward to move the attachments up. You would need it in front of the rockshaft or run a pulley and go past the rockshaft and come back to it and connect it.
Old 03-13-2013, 10:16 AM
Last time I checked you pull the lift handle back to raise the deck.
Old 03-13-2013, 10:40 AM
Muzzy Muzzy is offline
Now we know why you had to take the osha test 5 times.
Old 03-13-2013, 11:27 AM
yes you pull the lift handle, which makes the bottom of the lift handle move towards the front of the tractor, if you pull on the lift handle from underneath the tractor its going to push the top of the handle forward.
Whats going to happen when you pull on the blue line shown in this picture smart guys. Thats the only way i can see a winch being mounted under the tractor moving the lift arm.
Old 03-13-2013, 12:30 PM
Winch (in red) would go on top at rear. Cable along side the frame tunnel.
Old 03-13-2013, 01:33 PM
makes sense, I just can't figure out how that would be routed to work. There isn't much room
