Old 03-20-2013, 05:59 PM
inspectorudy's Avatar
I'm confused, nothing new there, because I do not see a three point hitch in any of the pictures. I see a lift only sleeve hitch with no down force except gravity. It would seem to me that if you want to use that sleeve hitch to plow with then you will need the two solid bars that go from the lift pin to the hitch and if you get the type with slots on one end then you can apply down force to start plowing and then the slots will let the plow jump up and down a little to prevent jerking the tractor when it encounters a rock or harder ground.
1811 Hydro
