Old 03-23-2013, 07:47 AM
Grampie Grampie is offline
Thumbs up Clean Lookin' 2084 !
Originally Posted by 105_Tom View Post
Thanks, Guys! I'll find plenty of stuff to get into with that Super. And, yes, the perfect tractor find is the best!
Congrats on finding your super cub! I think their the best driving tractor to have and Im sure you're going to enjoy it! I know that as long as Im alive here on this planet that I will not be without at least one! Nice Find!!!
Old 03-23-2013, 08:24 AM
Congrats on the 2084 and welcome to the Cyclops Club!
Old 03-23-2013, 11:20 AM
PaulS's Avatar
PaulS PaulS is offline
Welcome to the Cyclops club. As you can see I also own a 2084 and my son has a 2086 and we love them. P.S. mine also has diff front tires maybe it is a 2084 thing.
Old 03-23-2013, 11:29 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
why would you want to tear down a tractor in such good shape?
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 03-23-2013, 11:55 AM
Not sure it needs a total tear down but it wouldn’t hurt to pull the engine out and give it a good cleaning. The fins probably have some buildup. The CV joint for the tilt steering will need to be cleaned and re-packed and it is a PITA to get at with the engine in place. I’d check the CV joints on the drive shaft and make sure they have been greased and check the bolts that hold the rear end in to make sure they are tight and that the mounts are not broken. Change the Hy-Tran and filter. I'd also pull the fender pan, fuel tank and clean the crud off the top of the hydro and replace the bungs that go into the bottom of the fuel tank and replace the fuel lines. All this stuff is due at the age of this tractor. Ask me how I know.
Old 03-23-2013, 12:29 PM
PaulS's Avatar
Grease but absolutely do not over grease the cv joints, don't even ask how I know. Check both the front and rear oil seals. Remove all the tins around the engine and clean the fins well. Your tractor will run cooler doing that. I remove mine at least once a year to clean the engine fins. Something else that is opposite to other tractors is when you shut the engine down, first speed up the engine to at least half throttle and then shut it down. Otherwise backfires can occur and that is hard on head gaskets. Closely check the valve covers mine were cracked at the corners. The replacements worked perfectly with even an improved gasket seal. Keep that engine clean and it will go wherever and do whatever you have in mind.
Pulling the engine is just 4 bolts a few wires and then you can slide it forward enough to get to the fan shroud which has to be cleaned too. Mice and other critters like that area.
Old 03-23-2013, 02:05 PM
Tom Congrats on your awesome super cyclops! I'm glad your wait paid off!
Old 03-23-2013, 02:56 PM
cub123's Avatar
cub123 cub123 is offline
Congrats on your super cyclops! It looks like it's in real nice shape, just be careful, once you have one you just have to have another
Old 03-23-2013, 03:35 PM
Ben
Holler when you are ready for number 3 LMAO
Old 03-23-2013, 08:45 PM
cub123's Avatar
Ben
Only if it has a Kubota
