Old 05-27-2013, 10:47 AM
Darrell Darrell is offline
You don't have to unbolt the engine to pull the driveshaft.
Knock the pins out of the front/rear coupler , unbolt the front/rear couplers and the driveshaft will slide far enough in the adaptor bolted to the flywheel to clear the stub shaft. You may have to slide the rear coupler forward also , i can't remember for sure.
You may have to work the driveshaft around to make it slide thru the front coupler or pry the coupler back.
This will work on QL's also.
This is one of the first areas i look at when i get a new Cub. Seems like when i get a hydro Cub with the plastic hydro fan there are blades missing or no blades at all , especially on a QL.
Old 05-27-2013, 10:00 PM
scottmi65 scottmi65 is offline
Fan blades are all good and the rear joint feels tight. I may have caught this in time before it ate the metal parts up.
Old 05-30-2013, 08:00 PM
Considering what will be involved, just pull the drive shaft and replace all the flex discs and the front and rear ball bushings and all new spiral pins. You won't have to worry about it again for 15 maybe 20 years. I just did the whole thing to my 1711 late last year. Also to get the drive shaft out, you will need to loosen the four engine mount bolts and move the motor forward enough to make room to pull the drive shaft out.
Hey DX3 you were right both ball joints and the shaft were chewed up so made a new shaft today and will put here back together. When I bought the tractor the 6 bolts on the engine pan were either loose or missing so that probably did not help the drive joints.
Thanks
