Old 05-26-2013, 03:14 PM
scottmi65 scottmi65 is offline
Default Flex Joint
I noticed the flex joint on 1711 is bad, it looks like there are two flexes bolted together? When you buy a new one is it two disc or one disc?
Thanks
Old 05-26-2013, 04:14 PM
Flex Disc's are sold as EACH. You will need four.
Old 05-26-2013, 04:34 PM
Mcamp Mcamp is offline
Also be sure to check your ball bushings on both ends of the drive shaft.
Old 05-26-2013, 05:28 PM
Okay thanks I will pull the tunnel cover and look at the rears also
Old 05-26-2013, 05:57 PM
Considering what will be involved, just pull the drive shaft and replace all the flex discs and the front and rear ball bushings and all new spiral pins. You won't have to worry about it again for 15 maybe 20 years. I just did the whole thing to my 1711 late last year. Also to get the drive shaft out, you will need to loosen the four engine mount bolts and move the motor forward enough to make room to pull the drive shaft out.
Old 05-26-2013, 06:02 PM
The last one I fooled with was REALLY hard to get it to align.
I think once those splines wear some, getting the driveshaft to not wobble is a real art.
Tighten this bolt, loosen that bolt, shim here, etc,,,,,,etc.....PHEW!!!
Did I miss something? Or, is there a better way?
Old 05-26-2013, 06:15 PM
I don't know CAD. Mine went together really well. The only part that was difficult was getting the motor moved back with one hand while getting the drive shaft to slide into the ball bushing with the other. Once I had that done, it all bolted up fine. Now you have me wondering if I did something wrong.
Old 05-26-2013, 06:21 PM
There ain't nothing wrong, if the driveshaft spins "true".
Mine was flopping around like a baby rattle!!
Tweak, tweak,,,,,,, The worn 128 style driveline looks good to me, after fooling with those discs!!
Old 05-26-2013, 06:55 PM
I'm trying to get my tractors off the rag....joints LOL
Old 05-27-2013, 08:53 AM
Default Poly disc
Another possibility:
http://www.ebay.com/itm/NEW-RELIANCE...-/300636837649
About 20+ years ago, I changed over 3-4 of my tractors from the rag coupling to the poly disc. These things are used as drive couplings between big electric motors and conveyor gearboxes and probably other uses. They're extremely tough!
I used them for several years and they worked without distortion. Of course I put in new driveshafts, couplings, balls or whatever was required to repair worn steel parts. I don't know how long they will last because I only used the tractors daily for a few years and then parked them. They're still in the tractors today.
