the popping out the ex could be the ex valve not closing all the way. the rust you see in the intake when you took the carb off is prob from water getting in while it was sitting. I would pull the head and check to see if the valves are closing and clean out any carbon that is in there.
Cub Cadets & IH tractors 1811 - 1090 hours 1872 basket case, rebuilding. #1 tiller 1 Farmall regular |
http://mgonitzke.net16.net/tools/carb_rebuild.pdf Good luck!!
-Ryan
So a quick update!
I had the carb off and went through it so that gas actually gets into the fuel bowl now and everything looks clear. Reinstalled and put up my makeshift fuel tank (a fuel line with a funnel on top, so I can watch the gas levels and such.) Good batt, and cranking over fine. But the gas level in the funnel never changed. Put gas down the spark plug and still nothing... Today I got brave and took the head off and found this: ![]() ![]() ![]() Yeah, I have a stuck exhaust valve... Suggestions? Where do I go from here? No scrapes or gouges in the cylinder, so I guess that's something!
Thanks for updating us!
It may not be stuck, there is a decompressor built into the motor. If it opens & closes "most of the way" you may be OK. It could be the decompressor cam is stuck. Check the points & condensor also.
if the valve doesn't move I typically will spray some pb blaster on the valve and keep working it till it is free
I put some penetrating oil on the stuck valve, and I hope its just frozen in place and this will loosen it after a while.
More updates to come! |
Another update, this one better!
![]() So the valve was stuck, nothing in the engine was forcing it to stick, so I took it to a friend that builds engines and a case of beer later it was freed up! Today i reconnected the choke and throttle, reconnected the carb, and tossed some gas in. Fired up and ran ok, but needs some tweaking. I do not have the tank on there currently needs cleaning and new fuel lines, so I was running it off the smallest funnel in the world so I needed to keep refilling that vs start messing with the carb and tuning it. I did notice it got really pretty hot quick, is there anything against power washing the gunk off the engine? If I cover exhaust and carb, I should be able to spray it off right? There looks to be a lot of 30 year+ old gunk and dirt on there, so that may let it cool better once cleaned off. Little this, little that, and I will be well on my way to its first drive under its own power, and putting the deck on and cutting my yard! Thanks for reading, love all the advice I am getting from everyone! |
Great to hear!
