The center spindle is sitting at a SEVERE angle for some reason. It needs to be level like the other two blades. That may be the reason your belt is coming off.
You probably should look at that first. |
Here is a pic of a subframe for the deck you have.
That's what I thought too Lew, wrong sub-frame. So, the one he has, what deck is it for?
![]() Also, I believe that the mule drive pulley on the R.H. side (as sitting in the seat) needs to be on the other side of the arm. Or the arm is bent or something. They shouldn't be that close together. |
Under edit...
He has a subframe for a 38" timed deck that you could get a conversion kit to fit on the newer tractors at the time. Pics of the eye bolt part of it is different, so it will not lift the front up higher. If you look at the front where the mule drive attaches you can still see the original hangers turned up under mulde drive pulley assembly. That was easy.
This it the sub frame that came with my nf pallet tractor. Notice the straps on the rear to lower the back of the deck.image.jpg
I don't use my Cub. I just work on it and look at it. So far it's holding up very well. |
So Lew, you're saying this subframe is for a deck like the originals have? This is the subframe that came with my tractor, I just never used it. Took the deck off as soon as I got the tractor. So a different subframe and I'll be all set correct?
Thanks, Brent |
Yes it is for an Original,you should take off those brackets you have under the mule drive that are still on the tractor also and hang on to them.
A different subframe would work,but if it had a O deck on it the mule drive pulley setup will be different.Got some good pics of it? Download the cpe mowers in the tech section and check out the differences.
![]() ![]() ![]() ![]() Thanks, Brent |
http://onlycubcadets.net/forum/showthread.php?t=32360
This is a subframe Sam is selling. Is this what I would need? Then possibly the mule drive. |
Looks correct to me .
the one sam is selling is for a qa.you need a pin on one.
