Old 12-02-2013, 07:56 AM
sbauerz28's Avatar
Now that I have this blower and cab repainted it makes my tractor look bad. Maybe next year I will repaint it. I've smelled enough paint fumes for one season.
Old 12-02-2013, 11:29 AM
Cab turned out very nice!
Old 12-02-2013, 11:36 AM
Outstanding job on your cab!
Old 12-02-2013, 07:53 PM
EricR's Avatar
EricR EricR is offline
Yep good job.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 12-02-2013, 11:30 PM
Great looking set up!! For safety, you may want some lights on the back of your cub or cab so that you are easily identified if you plow anything in or across the roadway. The paint really made a big difference in the way that it looks--sweet job!
Old 12-06-2013, 02:53 PM
squatch squatch is offline
You did a great job. You'll enjoy that cab when it's cold and blowing! Don't really need heat. Just the cab is a full layer of clothes you don't have to wear!
The metal cabs tend to channel and amplify noise from the machine as well as drumming from the road. Get some hearing protectors. Also in mine the windshield likes to ice up. So I installed a little 12v fan from Big Lots. It's like the ones folks use in their cubicals at work. It works like a charm to keep the window clear. I also like the idea I'm circulating air inside the cab. Can't be too careful with exhaust fumes.
I installed reflectors on my cab and they work well. if I was on a main road I would add an amber beacon on the roof.
Some pics that might give you some ideas.
http://www.onlycubcadets.net/forum/s...ead.php?t=7382
http://www.onlycubcadets.net/forum/s...ad.php?t=15501
I have some WR Grace ice dam guard for roofing left over from a project. It's a tar like film with plastic on it. I've heard of some folks using it like Dynamat to dampen panel drumming. I think I'm going to try to put some of that in my cab this winter and see how it works. Should take some of the loudness out of the flat metal.
