Old 02-03-2014, 03:29 AM
TheSaturnV's Avatar
Just an update, I found the original Tstat. I don't notice much at all as far as how it runs or warms up. Since it's apparently so important to engine wear, I will likely pull it back out soon and put a thermometer to it to see if it's opening to spec.
Thanks for the help all.
Old 02-03-2014, 10:36 AM
782CC 782CC is offline
Warmup is identical up to the 160 degrees so should not see anything different in that regard. Before you put the old one in you could test it on the stove (water).
