Old 01-27-2014, 04:57 AM
TheSaturnV's Avatar
Default Anyone running a 71 degree thermostat in their Kubota D600?
Hey all,
Being doing a cooling system overhaul in the form of a new water pump and hoses. While I had it apart, I somehow misplaced the original thermostat. I happened to have another on hand that I mistakenly purchased awhile back.
The original is an 82 degree Tstat, and as I mentioned the new one is 71. It's in the 882 and has no cooling issues at all. Will the lower temps cause the engine to detonate poorly?
Old 01-27-2014, 08:37 AM
I doubt that it will make any difference
Old 01-27-2014, 09:50 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
Just really watch the temp when its 80 / 90 ยบ + outside. The smaller temp stat wont close long enough to let the radiator cool . Then all it will do is circulate hot fluid.
Doug
Original , 100 , 125 , 582
Old 01-27-2014, 10:24 AM
Doug
I would think it should run cooler since it opens at a lower temp.
Old 01-27-2014, 11:09 AM
I'm with Sam. And I think you mean 171 degree.
Old 01-27-2014, 11:21 AM
I think he's talking Celsius
Old 01-27-2014, 12:07 PM
Oh. Well.... lets see. ummmmmmmm
Google says that is 180 degree to 160 degree. It won't hurt anything. But personally, I wouldn't. I don't like to go colder unless absolutely necessary.
But that partially comes from today's modern engines. The computer does funny things if the t-stat temp isn't correct.
Old 01-27-2014, 02:26 PM
TheSaturnV's Avatar
Yes, modern automobile engines would surely not like a mismatched Tstat. I'm thinking the little D600 is old enough it won't care one way or another. Guess I'll try it for awhile and see what the summer operation brings.
Old 01-27-2014, 07:22 PM
782CC 782CC is offline
Older engines would run ok, but the cooler water did cause uneven wear on the cylinders. The cylinder would egg with wear being more prominent at the spots the water hit the cylinder.
It should run fine. Maybe not a good on fuel. But suggest putting the 71 deg back in when you get the chance.
Old 01-27-2014, 08:35 PM
TheSaturnV's Avatar
Agreed, at the least I've a little bit more about engines and whatnot. I'll get a new one on order so the old one will turn up once I pay...
