Old 02-05-2014, 05:58 PM
That looks good Sam! I need to do that to one of mine too!
Old 02-05-2014, 08:21 PM
Mike it's an easy fix. When I bought this one it had a zip tie to shut it off. Talk about barn yard engineering.
Old 02-06-2014, 07:06 AM
LOL
When I bought my 782D the PO had a wire coming through the pedestal that you pull to shut it off. I want to do a little cleaner job on it!
Old 02-06-2014, 09:37 AM
Mcamp Mcamp is offline
Mike, the 782d has 2 cables on the throttle,one for shutdown and one for rpms. I just bought a shut down cable in the fall for a 782d i was working on from the cub dealer,don't think it was to expensive IMO, just a pain to install.LOL
Old 02-06-2014, 12:34 PM
Thanks Mark! I will check that out.
Old 02-06-2014, 10:37 PM
V30crewcab V30crewcab is offline
sounds like its not getting the trigger from the starter wire. its wired exactly like a cummins truck, a ground, the pull wire, and the hold wire. when you hit the key to power the starter, it sends power to the strong pull part of the solenoid. theres a smaller part of the solenoid that holds it in as long as the key is on. mine was kicking off when I hit a bump or something as well. I had to take the end off the shutdown lever, energize the solenoid to the run position, and bend the lever so it lined up in the full on position. it was bent so the solenoid couldn't move in all the way, and it would let loose easily.
I know everyone likes the simplicity of the cable, but I like mine working with the key like it was built. I had a cable on my chevy truck with a cummins when I first built it, then I got in a wreck, shut the key off and the engine didn't quit. took me a few seconds to realize I had to pull the cable. decided it was a safety hazard to have it that way so bought the right part and fixed it.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-06-2014, 11:08 PM
You must have a dealer who had one. Cub Cadet shows that cable NLA.
The "right part" is NLA. You would have to get a different one and make it work. Shut-downs are $$$ for good ones. Cables are a good, cheap and an easy fix. Plus, on a tractor, pretty normal. Deere and Case used them for a long, LONG time.
Old 02-07-2014, 07:10 AM
Yeah, it does look like it is NLA.
I know what dealer Mark deals with so I will see if they have anymore.
Old 02-07-2014, 09:36 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
go with the cable shut down. diesels run much better with out all the electronic crap. proof is my 45 year old case backhoe. lets see a diesel built today in 45 years.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 02-09-2014, 10:26 PM
Looks like its available here: http://www.woodward.com/EngineSolenoidShutDownKits.aspx as the Kubota 1a kit.
I understand most people want the cable, but for my machine if it goes out, I will be putting the original style back on it. Just figured I'd let everyone know there is still the option.
also you can search ebay for the part# and they come up for a decent price as well. SA-4269-12 is the part# for the solenoid, and you just reuse your metal rod end from the old one.
72 scout
IH 404 tractor
Tags
1782 cub cadet, shutdown solenoid, solenoid
