Old 02-03-2015, 05:45 PM
yeeter yeeter is offline
Interesting. Tonights plow duty was dry. Cold, but dry.
Ran like a top.
We may be onto something with this wet causing electrical issues concept....
Makes we want to get the garden hose out and spray it down just to test. Um... nah, still in the teens.
Old 02-03-2015, 07:25 PM
Is it possible you had carburetor icing?
Old 02-03-2015, 07:34 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
After you're done plowing next time, squirt the plug wires with soapy water before put it to bed. If it's dark and the wires are bad, it'll look like July 4th.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-03-2015, 09:34 PM
Well, until I can turn the problem on and off I won't really know. Sure could have had some water in the bowl, or some other place icing. Or could be electrical. Wires, switch, etc.
Or maybe one of those elusive problems which magically goes away and never returns.
I did flush the tank and drain the carb bowl, in addition to having the plugs in/out. None of that mattered that particular night. We will see what the next run behaves like, more snow Thursday (have had 58" of snow this week!)
Maybe this weekend I can pull it inside and give the carb a good cleaning, but did that not long ago.
Thanks for all the good advice, I will work through it all. Slowly, but will get through the suggestions. Some plugs and wires and fuel line and a filter wouldn't be a bad idea. And that ignition switch was misbehaving last fall, so add that to the suspect list. While I am at it might as well do an oil and filter change. Just did the hydro fluid.
Sounds like a project for the weekend. I need to look up what plugs and what weight oil to run. Any suggestions on the plug wires? Oh, and gas line size/material type. A trip to Napa at lunch it seems.
Old 02-04-2015, 07:39 AM
Quick question (making my shopping list):
Is there a particular fuel line material the group would recommend? I have heard the ethanol breaks down certain types.
If I read the specs right, its 1/4" ID. I thought I would ask here first.
Then ditto on spark plug wires: Any particular type you guru's prefer over the others?
(Im not even going to ask about spark plug brand, religion, or politics....)
Old 02-04-2015, 07:45 AM
Something else to consider,
Those head mounted ign modules usually collect junk/clippings and either fail
or possibly shorting out because of moisture?? just a thought.
I have an after mkt Ign module on my m-18 and it will not produce spark @ low cranking speeds.
one of these days I'm gonna pitch it and go genuine kohler!
