Old 03-17-2016, 12:37 AM
bocephus1991's Avatar
If the bearings look and feel good, I don't replace them. A ball bearing running in oil lasts a very long time.
And those old bearings were probably made of better, or more pure steel than the ones made today.
Brian
Old 03-17-2016, 08:24 PM
SLS327 SLS327 is offline
What does brgs stand for? Bearings?
Yes, brg is short acronym for bearing. I am going to reuse them, cleaned up and oiled again, ran very smooth. Below are the crankshaft measurements. The cylinder bore was about .005 taper top to bottom and not out of round, 3.380 at the top, along with those scuff marks on the side. I was wandering about the crank and having it reground? Below are the measurements from the crank, with a micrometer.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 03-17-2016, 08:50 PM
Grind it. Always.
Old 03-17-2016, 10:02 PM
As Jon said, grind it. Better you have a known true round surface for the rod than an egg shaped one or an unknown.
Brian
Old 03-29-2016, 10:37 PM
Thanks for the help on this. This is one place I want to be sure everything is good, I am taking the crank in to grind .010 under and the cylinder will clean up at .010 over, too. I Got the kit ordered from the aftermarket retailer on ebay. In the meantime, found several things that need to be fixed, this will keep me busy till the block and crank are done.
Steven
Old 04-03-2016, 01:19 AM
Default engine work
I took the crankshaft to the machine shop today 45 min away and found out their machinist that had been there 45 years retired, they have a new guy, but not quit ready to do crankshafts yet. They have another place about a half hour away where the are going to send it too. This is the first time I have looked for a place to have engine work done. anyway just wanted to post a couple pictures of the crankshaft journal before and new rod, measured 1.49, so it is undersized. The piston was marked with a .01 over on top. But I found it interesting there was no markings of any type on the rings to indicate .01 over or a dot. But there was some good instructions for installation.
Steven
Old 04-03-2016, 09:01 AM
Rings are not usually marked except for the package/paper they come in.
It is always best check end gap in the cylinder before installing on piston.
I have seen chit happen,don't ASSUME anything!
it will bite you in the arse
I could tell stories, as a lot of us could.
Old 04-03-2016, 09:48 AM
Terry C's Avatar
Terry C Terry C is offline
I know you are from. I met you once at Meisners. Where did you take the crank?
There is a guy in South Sioux that does cranks and all engine machine work
PM me and I can give you some names
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-03-2016, 11:14 AM
So, did the crank get ground? I can't tell from the pic.
Old 04-03-2016, 02:08 PM
Not yet, just dropped it off yesterday. probably be back end of this week or longer. they quoted me 40 for the block and 65 for the crank, but since the crank has to go elsewhere the labor rates may be different. I will find out Monday. I have a machinist friend doing the block for me, he is honing it with a sunnex hone and is taking the last .0015 off now that he has the piston. I will post pictures of both when they get back.
Steven
