Old 05-04-2016, 09:11 PM
Originally Posted by Billy-O View Post
I think Red Green might have done something like that!
Old 05-05-2016, 12:57 PM
I'd like to see a pic of this.
Sure let me just get out my $2000 tiny boroscope w/digital camera
,if I can pull it out ( the screen filter) I will post that
I kind of remember a lawnmower shop having these in the eightys now ,up by the cash box 3 different sizes on a card with a stick tool to insert on a make shift temp repair
If I can get a new jet, jb weld it in or replace the carb
Old 05-05-2016, 01:36 PM
A boroscope with a camera doesn't cost that much......
Snap-On has a digital, wireless, with live recording and camera for $1250.
I think you are mistaken about replacing the jet with a screen. I would come nearer to thinking someone offered a screen, to keep debris out of the jet. Not to replace it.
I still have no idea why you would want to do this anyway.....
Old 05-05-2016, 05:31 PM
My solution to the problem would be to replace the carb and be done with the issue. Do as you see fit, it's your engine. Just a FYI you said you have an opposed Vanguard, if it is a horizontally opposed twin it is not a Vanguard, Vanguard twins are V-twins.
Old 05-05-2016, 11:34 PM
Jmech
I found it that way with the ariator screen jammed in the main jet opening ( it was running lean so I opened it up ) if you took out the jet and the threads got gaulded or cross threaded ..your screwed
the screen was a way to have it run temperarily
I want to put it back to stock or replace the carb ...of course
yes it is opposed a 97
and ebay has a digital boroscope for $ 129 wow
http://www.ebay.com/itm/Autel-MV400-...809591&vxp=mtr
Old 05-06-2016, 07:54 AM
What model tractor are you working on? What are the numbers on the engine? I need more info in order to help.
Old 05-06-2016, 04:49 PM
Model #460777
. 20hp diamond i/c
97 mtd gt
Looking to try a new jet first unless I could get a used carb cheap
Old 05-06-2016, 05:10 PM
Maybe this will help.
http://www.jackssmallengines.com/jac...ts-fuel-pump-1
Just a FYI that engine is not a Vanguard, it's a Briggs I/C horizontally opposed twin.
Old 05-06-2016, 06:05 PM
I don't see any screens in that parts diagram......
