Old 09-16-2016, 09:24 PM
it should be like this. This is the front blade I use on both of my 125's
Old 09-17-2016, 11:00 AM
Under carriage= subframe. Connects both at the QA attach at the front AND to the rockshaft under your feet. Not entirely necessary to push snow/dirt, but a good idea especially when you are pushing a whole lotta snow and don't know what's under the snow then BLAAAMMM it shudders the whole tractor. PS when pushing snow remove the trip lock out so the blade can trip.
Old 09-19-2016, 11:51 AM
ambrola's Avatar
ambrola ambrola is offline
I'm just gonna leave it as is unless someone comes up with the part I need. We don't get much snow here in this part of NC. But when we do, it's normally a lot, and I have a long driveway.
PS: What is a rockshaft? Everyone keeps mentioning it?
Old 09-19-2016, 12:19 PM
Rockshaft in this case is the shaft under the footrests that the implement lift handle is attached to (it doesn't spin like a shaft in other applications, it just rocks back and forth).
Old 09-19-2016, 12:55 PM
Terry C's Avatar
Terry C Terry C is offline
I think rockshaft is not what the blade subframe hooks to. I've always called the shaft that pivots when you move the lift arm the rockshsft. The subframe hooks on the 3/4 round bar that is at the back of your footrest. It goes all the way across the tractor.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-19-2016, 12:56 PM
ambrola's Avatar
Smile
Thanks, Now I understand.
Old 09-19-2016, 02:21 PM
Just to clarify,
On the Narrow Frame tractors the little "forks" on the blade subframe slip around the implement lift rock shaft.
On Wide Frame tractors, the forks attach to the 3/4" bar that's welded to the underside of the frame.
Old 09-19-2016, 02:23 PM
Terry C's Avatar
Just to clarify,
Sorry I forgot he's talking about a 122. My mistake
Terry
3225
