Old 12-21-2017, 12:29 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default blower lift
That amount of lift is all I get with a Q42A on my Yellow 782 with curved upper arms
Userj8670's Avatar
Originally Posted by DeltaCub View Post
What is that blue sparkly light between the coil and the side cover?
That is the flux capacitor!
Naw it's the Transdenser - points saver....kibda have some buyers remorse on that lol
Old 12-21-2017, 12:32 PM
Userj8670's Avatar
Originally Posted by ironman View Post
Lift height issue first, remove the rod from your lift arm so that the thrower is out of the picture. Then run your lift full travel bottom to top. At the full up position If the lift arm goes further towards the rear of the tractor than it does in your video then something with the thrower is stopping the lift. If it doesn't, you have something on the tractor not right. Remove the center cover and have a look.
As far as being lopsided, your video leaves alot to be desired to be able to help you. I'm gonna go take some picks of mine, maybe will help, be right back.
I'll grab another vid when I get home later - I like vids because this way, you all can clearly see what I see vs. me trying to describe.
I'll measure the lift rod as well. But yea, I was always baffled at the limited amount of distance the hydro "ear" travels
Old 12-21-2017, 12:51 PM
ironman's Avatar
ironman ironman is offline
Here are pics of mine (on a 149)
First is the lift arm with lift fully raised. It looks to go to the same place as yours does in the video. The next is the lift fully lowered with the thrower on the ground. The third and fourth is the thrower mechanisim raise and lowered.
Fifth and sixth are lift rod length (my lift rod is adjustable) and thrower height fully raised.
So watching your video again, my conclusion is that your lift rod is too long.
Old 12-22-2017, 10:52 AM
Userj8670's Avatar
Thanks for the reply. Maybe my lift arm is to long? I measured it at 27 inches last night give or take. The blower in the raised position was 2inches on the "passenger" side and 1/2 inch on the "driver" side....certainly not a ton of clearance. This measurement was taken at the skids. Please see the attached videohttps://m.youtube.com/watch?v=lHTXxt_i2FQ
P.s. where might I obtain an adjustable lift arm like yours?! I like it alot
Old 12-22-2017, 12:10 PM
xtrememotorworks.com
Aaron, the guy who owns xtreme, makes adjustable lift rods.
Old 12-22-2017, 12:33 PM
Jeff in PA also makes adjustable lift rods.
Pap's 100
Restored 108
1211 Dual Stick
1050
