Buddy of mine just blew up his enclosed trailer and burnt it to the ground w/2 cubs, an outboard, a gen set and all his tools due to gas fumes. Dumb ass.
If Ya take cubs to RPRU and it's inside a bldg., better be prepared to shut off the gas and seal the vent in the tank. Fire code, Ya know! Worked the Cub display last year at Des Moines and we had more than on disgruntled exhibitor that chose to set up outside in the heat when they could have been inside in the A/C comfort. |
Back on track. I like the idea for the side panel screws. Much easier than having to get a socket and ratchet. I am going to copy the idea for my 1650 loader tractor.
Thanks for posting. |
If one puts the bolts in from the back side, you have studs to hang the side panels on, and use big wing nuts like the old vehicle air cleaners did back in the day, works for me.
We have the winner!
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
I use these.
No extra hardware, or tools needed. Plus you can really torque them down with just your fingers. Available at any hardware store, be sure not to get the bigger ones though. |
That's what I use and I actually leave the left side knob off most of the time. The spring in the front holds the side panel on just fine and it's easy to pull the panel out just a bit to turn the gas on and off. |
I just wanted to make a one piece screw that didn't need washers. Mine don't need washers. No loose parts.
Randy 1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift |
I thought about that, too. Mine are all one piece so I don't have to use washers and wing nuts. No loose parts.
no loose parts here either, just get washers w/smaller holes and screw 'em onto the wing nut 1st....
whatever..... |
