Old 12-17-2018, 09:04 AM
I'll ask once again
Just what exactly is the correct group # battery for the 882/1512 Cub??
More CCA needed for sure , because when you fire the preheat for a bit, the smaller GT/Lawn batteries, in cold conditions, don't have enough oomph left to spin fast/long enough to get the fire in all 3 lit.
Old 12-17-2018, 12:02 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
Allen, does your 1512 have the starter and GP upgrade yet? It makes a big difference when it is done. I've had good luck with Deka batteries and as the others have said, get the largest CCA you can. I keep a battery maintainer on mine too. Here is one I like from Hazard Freight and I've seen them go on sale for about $25.
https://www.harborfreight.com/4-amp-...ner-63350.html
Your shed probably stays cold this time of year so as Sam has suggested a block heater of some type would be a big +.
I agree 100% with Oak here. I too have the Harbor Freight battery maintainer and I am thoroughly impressed with it. I live in the snow belt and plow with my cobbled up diesel SGT (large auto battery installed at the rear) throughout the winter and keep the maintainer on it. In fact, I use the larger battery charger/winter maintainer from Harbor Freight on my old 7.3 Powerstroke. Definitely an investment I recommend as these high CCA batteries can be pricey when they need replaced!
https://www.harborfreight.com/automo...ger-63299.html
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 12-17-2018, 02:00 PM
bill682 bill682 is offline
I'll ask once again
They came from the factory with a U1 L&G battery. There are some improvements you can make for cold weather starting. Alterations to the battery box will be needed for a larger battery.
Old 12-17-2018, 02:22 PM
Box is already larger than the standard L&G battery.
Old 12-17-2018, 02:44 PM
I thought it was tight fit. Maybe I'm wrong?
Old 12-17-2018, 04:53 PM
I thought I posted a large image? I'll try again.
Admin Note: You did. I resized it so it wouldn't run off the screen and the people with limited internet could open it.
Old 12-17-2018, 06:04 PM
Admin Note: You did. I resized it so it wouldn't run off the screen and the people with limited internet could open it.[/QUOTE]
I thought I had the slowest internet. DSL
Old 12-17-2018, 06:16 PM
There are some with Dial Up in rural areas.
Old 12-17-2018, 06:48 PM
Bill, is that a single stick 782D? I've never seen one of those. I'm also seeing the heat baffle that didn't come out until the 1572.
Old 12-17-2018, 06:52 PM
V30crewcab V30crewcab is offline
I've had the best luck with an AGM battery from batteries plus. they last several years longer than a regular battery, and have better cca usually.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
