Old 04-28-2022, 06:04 PM
Marko141's Avatar
Marko141 Marko141 is offline
So I have some updates, I think the PO over filled the rear end. Oil coming out the top reliefs and also when I pull the plug on the rear it sprayed out.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 04-30-2022, 06:55 PM
dodge trucker dodge trucker is offline
Originally Posted by Billy-O View Post
That sucks..... If I llve near you I'd be over in a minute!
Doesn't look like it, I'm an hour south of Chicago.
Old 05-01-2022, 02:09 PM
johncub7172's Avatar
I'm in agreement with the board identifying the cork gasket and possibly a relief valve being the major suspects of a leaking transmission. I like to allow the pump once removed to drain fluid so I'm not draining fluid during reassembly. I used w new cork gasket with the non sticky adhesive, installed dry. I used acetone for final assembly on the mating surfaces. I just done this on a 1650 yesterday for a customer friend with good results. Good time to replace the hydraulic oil filter if needed.
