Old 11-26-2024, 09:07 PM
SDBOB SDBOB is offline
That looks like the mount I have. Distance between tabs where round pins are,is about 10.25" inches.
Old 11-30-2024, 10:47 AM
green407's Avatar
green407 green407 is offline
Sorry I haven't replied in a while.
If I'm understanding correctly, you want to use your narrow frame dozer blade on your wide frame cub?
I don't know much about the external width of the narrow frames but if the tabs fit within the latches of the wide frame then I say sure, it will work.
like finsruskw said "will require some Butchering/grinding/drilling to get them out"
but I think you knew that.
I think what you gain is a blade that can be used on two different tractors.
128 X 2, 129, 149, 1250, 1450 x 2
Old 11-30-2024, 02:29 PM
ironman's Avatar
ironman ironman is offline
The difference between the wide frame and narrow frame is two inches,
therefore the difference between the quick attach "tabs" on a narrow subframe and a wide subframe would be two inches.
Those "tabs" are supposed to slide into the "slot" on each side of the tractor frame's quick attach mechanism. That's what gives it lateral stability.
The narrow subfame "tabs" will end up about an inch inward on each side instead of in the "slot" that they are supposed to be in.
Something will need to be addressed to stop it from sliding side to side.
