Old 12-27-2013, 08:04 PM
mikejr555 mikejr555 is offline
Thanks everyone. I am going to whip up a pair of those flat stock extensions and call it a day. I'll post pics when I get them on.
Old 12-27-2013, 10:17 PM
Looking forward to them!
Old 01-01-2014, 07:20 PM
Default Update
Well rather than make brackets I decided to repurpose an old mule drive to perform the same job. I took everything off the mule drive that wasn't welded on and then bolted it on the tractor. I then put the subframe in position and raised it until it lined up with an existing pair of holes on the mule drive and bolted it there. It now hangs clear of the axle and looks like it will work fine. I did it in a hurry today because we are expecting snow. I will take some pics and let you guys know how it works. If I like it I will probably leave it on for the winter then take it off and paint it in spring. Thanks again to everyone for the help.
Old 01-01-2014, 07:26 PM
Good to hear you got something to work.
Old 01-01-2014, 07:32 PM
EricR's Avatar
EricR EricR is offline
Good to hear you got it mounted. The way you did it is the way we have ours on our 102.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 01-01-2014, 10:43 PM
Glad you got it! I did it the same way, when I used the blade on my 100.
