Old 12-31-2013, 05:39 PM
CC102PULLER CC102PULLER is offline
[/ATTACH]My 61 O on 6x12's.[ATTACH]My Buddies 100 with dual. [/ATTACH] [ATTACH]45737 [/ATTACH]
Originally Posted by Vin122 View Post
The Dual off the ground is a 6x12 Ag tire(I think Montgomery Wards Ag), the inner is a 8.50-12x23 Firestone Ag. The 6x12 diameter is smaller, that pic just shows what a dual typically does while plowing. At a different plow day it was mounted on the 70. On average my 8.5" Firestone Ag Dual hangs out there barely touching the ground, but its a 30 pound weight.
Here's a pic of a friends cub showing the dual barely touching the ground.
61' Original
100- Puller(Dad's)
102-Puller
108-Puller(Son's)
122- mower
1250-hyd lift- work horse
1650-project
Old 12-31-2013, 06:20 PM
IIRC, I've seen pictures on the net, of someone on an Original, pulling a plow with two duels (for a total of 3) tires on the left side. not sure who it was but I believe that both duels were off the ground in the pictures.
I really don't think it matters so much it the tire touches the ground or not... I think it's all about the weight. As we all already know, weight and traction are our worst enemies.
Old 12-31-2013, 06:47 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Thanks for the info guys, helps a lot. Keep the pics coming...there all good
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 12-31-2013, 06:50 PM
johncub7172's Avatar
Why is it that the pic of you driving the 122 with the wheel off the ground, has the dual tire on it off the 70? Looks kinda fake.....
Do you suppose it would make more sense to put the skinny tire on the inside, and the larger tire on the outside? I'm going to try for my first ever plow day even if I don't pull next year over in P.A . Maybe I'll know a little better.
Old 12-31-2013, 07:00 PM
No, I think that would put an awful lot of stress on the inner tire rim. Typically, on a dual you run lower tire pressure so that the inside tire is carrying more weight. Then the dual, just helps. But, a smaller one on the outside really doesn't hurt..... just doesn't help much either except for weight.
I haven't ever heard anyone say they have, but I'm surprised no one busts a wheel rim using the "clamp on" or wheel spacer method. In my mind the "original" style dual wheel axle would be better. Puts the stress on the axle hub and not the rim. But it doesn't sound like it matters much.
Old 12-31-2013, 09:02 PM
Having used the set up, I had the same feeling, respectably. Its a whole new ball game in tractor stance and stability. The axels I have read about, seem to have been over-weighted, as in use with a F.E.L . The rear axels are not that thick of a diameter. I know the forum is not about my opinion,...... but I always practice keeping the wheel weights as close to the tractor as possible.
By the way, I like that/those dedicated duel wheel, rim center removed. Pretty much like what I see on some of the large agricultural farm tractors.
Old 01-01-2014, 12:25 AM
dirtcowboy's Avatar
From what ive gathered on the pros & cons im just gonna put the dual on and see what happens. I definitely like the way it looks & come spring/fall see how it performs.
Old 01-05-2014, 01:35 PM
dirtcowboy's Avatar
I thought id share a pic of how my 782 will look this coming spring with duals. I got the dual all painted up nice and in this pic the dual isnt mounted but is setting like it will be with my dual spacers. I cant mount the duals yet since i use this tractor to push snow with & with duals on the tractor would be wider than blade.
Old 01-05-2014, 05:34 PM
That should help you out!
Old 01-05-2014, 09:16 PM
Duals will look great!
