Old 12-30-2013, 06:53 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Default Dual for plowing
Has anyone ran a dual wheel on a 782 moldboard plowing? I have a dual wheel ready to go on but i need to get the spacer kit from miller tire. I run wheel weights also but like the way the dual looks but havnt plowed with a dual on yet. I will post some pics of my setup tommorow but if anybody else has pics of their plowing setup please feel free to share. Im using 23x10.50x12 tires.
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 12-30-2013, 07:00 PM
It won't touch the ground.......
Old 12-30-2013, 07:17 PM
dirtcowboy's Avatar
That was one of the problems i thought of but a couple guys guys said they run low tire pressure in the dual to make up for distance between ground. They said running a dual makes a little bit of difference unless on hard compacted ground. I dont know just trying to do my research, lol
Old 12-30-2013, 07:33 PM
macman81's Avatar
macman81 macman81 is offline
I have run a dual on my 782 and no it doesn't help at all, like J-mech said it doesn't even touch the ground most of the time. I just like the look lol
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 12-30-2013, 07:35 PM
macman81's Avatar
23x8.50 tru powers
John,
PROUD OWNER
Old 12-30-2013, 08:07 PM
dirtcowboy's Avatar
Thanks i appreciate the input very much. Im like yourself, i love the look of the dual on my 782 & i can put a 26 lbs wheel weight on the inside rim of the tractor wheel. What did you use for a spacer between the wheels? Should i run a spacer between the tires or butt them up next to each other & use carriage bolts to hold them together. Thanks in advance
Old 12-30-2013, 08:26 PM
macman81's Avatar
I use those 2" thick plastic rings that everyone sells....work very good and don't mess up the paint!
John,
PROUD OWNER
Old 12-30-2013, 08:40 PM
dirtcowboy's Avatar
Thats what i need Macman, i have 8 & 10 inch carriage bolts but need the 2“ plastic ring. I really dont wanna pay $50 for a plastic ring especially when i only need one but i guess i will have to.
Old 12-30-2013, 08:54 PM
Why not run dual 6's so both hit the ground? Your carriage bolts will work and you don't need the plastic rings, although I would recommend them!
Old 12-30-2013, 09:11 PM
dirtcowboy's Avatar
I dont have 6's right now & i have an extra 23x10.50
