Old 01-13-2014, 09:43 PM
Great looking project tractor Todd
Old 01-13-2014, 10:14 PM
Thanks guys, I hope I can get some work done to it this week and maybe fire it up on the weekend.
Ken, I'm missing the spacer for the ps bracket and used some large washers to make the difference up. I will probably turn the muffler up and I hope I have enough clearence.
Jonathan, I will drive the pump off of the front pto but I need to make the pump bracket out of an old mule drive I have. I always wanted to drive one off of the back of the hydro pump and use the rear case for the sump but I can't do that on this one because of the rear pto. I'm debating removing the pto clutch off the front and just use 2 sheaves that are the same size to give me a 1:1 ratio or just use a 4.6" sheave and leave the pto on. What do you see out there?
Randy, I missed the tiller. I tried hard to find it because they were going to try and use it on a cat 1 tractor and it would be turning the wrong direction...never found it
Allen, I should have this one at Vince's plowday for you to test drive.
Does anybody have any pics of how their loader pumps are mounted. This one was missing the complete pump and bracket and now I need to start from scratch. I'm thinking about changing all the hoses too because this thing sat outside for something like 10 years and they look pretty dry rotted. Anybody ever order them from Surplus Center?
Thanks again everybody, I will keep you all up to date and have lots of pics.
Old 01-13-2014, 10:17 PM
Sounds good to me, Todd!
Old 01-14-2014, 08:37 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
here is my Kwik-Way loader pump. if you need any other pics. let me know.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-14-2014, 08:47 AM
ken6x6's Avatar
you may even want to give KW a call and ask if they have any parts left. they are very help full. i got new seals for the cylinders from them.
i also have the PDF manual for it. let me know if you want me to email it to you.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-14-2014, 06:33 PM
CTRUEX CTRUEX is offline
D640, check
2000 series driveline, check
FEL, check
Rear PTO, check
What more could a guy want in a tractor? This will be one sweet machine when you get her all together.
Old 01-14-2014, 10:53 PM
Ken, thanks a bunch. Those pics will help me get something fabbed up. I think I have the PDF manual for it and I bet their phone number is on there too. I will try and give them a call and see if they have anything.
Thanks, Cory. I sure hope this tractor runs. I kinda bought it in pieces.
Old 01-15-2014, 06:43 PM
mpfeiffer mpfeiffer is offline
Oak, what have you found is the easiest way to remove the stock drive shaft in the 1772? I had the rear end out the last time to repair the cracked case, but I don't want to mess with those touchy rear end mounting bolts. Could slide engine up a hair, but maybe I am overlooking some easier way. May do one of the 3000 series updates. I don't use the tractor hardly at all anymore because my gas ones are so much smoother and I want to get it running 100% again.
Old 01-15-2014, 08:15 PM
Hi Matt, I've found that pulling the engine mount bolts and sliding the motor forward and to the side a bit is the easiest way, but Todd may have a better way of doing it.
Old 01-15-2014, 08:24 PM
Yep, slide the engine forward. You may want to do the CV type joints if your going to work it hard.
