Old 03-13-2015, 07:18 PM
If it is the proper PTO it should center itself. I have never seen a front PTO that the base (#1) had to be centered. Sam is correct, they all have a lip/tangs that sits in the seal bore to center it. Did you line it up?
I believe that that PTO butts up a lip on the crank. No bushing required. I don't see one listed in the parts book anywhere either. I have a motor sitting here, but I'm not taking it apart just to look.....
Old 03-13-2015, 09:38 PM
imnotacollector imnotacollector is offline
There is actually cut outs on the mounting plate of #1 that go over parts of the block. So I'm not sure what my problem is, but if those are right it should be centered. Right? If you look at the top left hand corner, just above the pto part #1, that is the cut out I'm talking about. The pto was on the opposed 16 Briggs I pulled out of the 582. Thanks again for your guy's help.
Old 03-13-2015, 10:28 PM
CubDieselFan's Avatar
What did the new engine come out of? Is the crank the same length?
Old 03-13-2015, 11:08 PM
If your using the PTO off the 16 on the 18, it may not work. May need a spacer or something.
I'm with CubDieselFan, crank looks too long.
Old 03-13-2015, 11:44 PM
When all the pto parts are on the shaft, the shaft sits flush with the outer part of the pulley. The guy I got the engine from ran a log splitter with it. If it was on anything else I'm not aware of it. I guess I'll just try cleaning up all the pto parts and see where that leaves me. Thanks
Old 03-14-2015, 12:32 AM
Why not measure the old engine crank and the newer one, then at least you'll know they are the same, or not.
Old 03-14-2015, 09:42 AM
mickb72 mickb72 is offline
Hello, you do not want #2 rubbing #1 or off goes the plastic covering the coil. May need a shim on the crank behind #2. I used that briggs pto on a 1"mag18 out of a roper in my 582 a couple years ago. Everything works good, i maybe need to revisit the rubbing part. BECAUSE this year i learned about the rubbing part when i put a ch18 in a 682 and used the pto off the kt motor. I'm afraid to say anything on here anymore for fear of getting flamed when people don't quite understand your way of thinking or expressing. Mike
Old 03-14-2015, 01:18 PM
Both shafts are measuring the same @ 2 13/16".
Old 03-14-2015, 02:55 PM
Mike
Please feel free to post away, if you can help the OP that's what the forum is all about. If something is bothering you send me a PM with your phone # and I'll give you a call.
Old 03-17-2015, 01:21 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default 582 motor
I had a 582 a few years back that I redid.I used a 16hp ring gear motor and made a 2 plug head and a coil off a twin,it also had the 18hp cam it was a real beast
